Head light question
Old Feb 4, 2007 | 10:20 PM
69any1's Avatar
69any1
Default Head light question
I have a 69 and i was wondering where i should get some new headlights from.. Do i have to change the whole light or is it just a bulb?? The 2 outside lights are working and the 2 inner lights arent. Are those my brights??? Over all i want to replace all 4.. where and what should i get??
Old Feb 4, 2007 | 10:50 PM
bluthundr's Avatar
bluthundr
Autozone, Advance, your normal part places should have the bulbs. They are the entire glass light. Yes, the two inside ones are your brights.
Old Feb 5, 2007 | 07:48 AM
saudivette's Avatar
saudivette
Originally Posted by 69any1
...Do i have to change the whole light or is it just a bulb??
Mine are sealed beams so I would assume you replace the unit on yours too...
...The 2 outside lights are working and the 2 inner lights arent.
Mine were doing that a while ago and it was actually the dip switch that was broken and so the high beams coudn't work. Might be worth checking that before you replace the lights...
...Are those my brights???
Yes...
Old Feb 5, 2007 | 08:05 AM
Gordonm's Avatar
Gordonm
I put in standard Halogen bulbs in all 4 of mine. I was amazed at how much brighter it was. They are just regular 4 headlight systems. Nothing special needed.
Old Feb 5, 2007 | 09:28 AM
69any1's Avatar
69any1
I am gonna get the halogens for it.. The 2 that work the beam is an ugly yellow!!!
So If i replace them all... I need low beams for the outside and high beams for the inside???
Old Feb 5, 2007 | 09:31 AM
Vette Gator's Avatar
Vette Gator
Yep.
Old Feb 5, 2007 | 10:42 AM
sly vette's Avatar
sly vette
Don't forget to check that dimmer switch!!!!
Old Feb 5, 2007 | 11:15 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Inners are high beam. Odd to have them both go at the same time. Have you checked the switch?
Old Feb 5, 2007 | 01:20 PM
69any1's Avatar
69any1
The vette has been sitting for at least 3 years.. Those bulbs could have went out years ago and my old man never changed them!!! Im gonna replace them all and go from there!! Some of the connections might be bad so well see. PLus the lights are YELLOW right now.. I was just happy the lights popped up
Old Feb 5, 2007 | 01:54 PM
7T1vette's Avatar
7T1vette
Fog must be a frequent occurrence in your area for someone to have put in yellow lights. You should check that the "bright" lamp sockets are working when you get them apart (try one of the low-beam bulbs in a high-beam socket). You may have a switch, wiring, or relay problem with the high-beam lamps.
Old Feb 5, 2007 | 04:54 PM
sly vette's Avatar
sly vette
CHECK THE DIMMER SWITCH!!!
Old Feb 6, 2007 | 11:31 AM
69any1's Avatar
69any1
wheres that located??? The dimmer part where u turn the lights on???
Old Feb 6, 2007 | 11:45 AM
sly vette's Avatar
sly vette
On a '69 as I have the dimmer switch is located to the far left, near the kick panel. Pull the carpet back and you will see a small black pedal. Under the pedal you will find the switch.
Good Luck!
Old Feb 6, 2007 | 11:54 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I replaced my original T3's with a set from Lectric Limited. They look original but perform much better. http://www.lectriclimited.com/mainpage.htm
Old Feb 6, 2007 | 12:07 PM
saudivette's Avatar
saudivette
No, your hi beam/low beam switch...
Old Feb 6, 2007 | 01:08 PM
69any1's Avatar
69any1
Im all over that switch.. I click it and my high beams come on...
Old Feb 6, 2007 | 01:31 PM
Easy Mike's Avatar
Easy Mike
My advice would be to order a reproduction owner's manual (if you don't have an original) and read through it. Things like high beam operation are discussed and explained in the owner's manual.
Old Feb 6, 2007 | 04:01 PM
saudivette's Avatar
saudivette
Cool!
To Head light question
