Engine Stamp Pad - help ID engine T0615XCH
I am looking for some help id'ing an engine.
It is a 454 and I believe it is between 1971 and 1974.
Only stamped number on the pad is TO615XCH, please note this is what I believe is the number, little faint. No VIN number stamped
Lastly, can someone send me a picture or clear description where to find the date code of the block and an example code how to determine the date.
I am getting ready to list this item for sale and I want to be as open as I can.
Thanks for all your help.
Scott
http://www.yearone.com/updatedsingle...gineinfo6.html
This site will supply you with the suffix codes
http://www.nastyz28.com/chevy-engine-code-stampings.php
Where did you find this information out since every where that I look I can not find the information.
Would anyone have interest in this motor? Lastly, what do you think I should ask for it? Running motor with all forged parts and large connecting rod bolts, forged pistons, 4 bolt main, low rise LS6 intake.
THanks
Scott
p/n 3965774
454 CID, RPO LS7, 12.25:1 Compression,
4-bolt main iron block, 5140 forged steel crank
w/ cross-drilled mains 3963524, 4340 forged steel
connecting rods w/ 7/16-in. bolts for pressed pins
3963552, forged hi-dome pistons, racing mechanical
camshaft 3959180, open-chamber cast-iron cylinder
heads 6260482, balancer 3963530, standard flywheel
3993827, (does not include water pump or intake
manifold). (No partial engine available)
(ENGINE SUFFIX XCH)
That cam is the 2nd design L88 with .560 and .600 lifts. The part number of the heads is 6260482 but not sure what the casting number is, could be 3994026 but don't know.
I would think there would be an interest in it but not sure exactly what. Guess like any engine will depend on the current condition and overbore. Is it in running condition now?
Oh, and the date code will be on the back top of the block on the right side next to the distributor, will be a letter and 3 or 4 numbers. The block casting number is in the same location but opposite side.
The engine is running - never been bored.
Cylinder walls look really good, still have the cross hatching. I am willing to bet that the motor has very little if any hours on it.
Thanks again
Scott
I did check the date code on the backof the motor, early June 1973
I will probably clean it up and stick it on the infamous e-bay.
I would love to keep it but I really don't have a use for it
SAS
I'm thinking that since a stock L88 with open headers will make about 520-530 gross hp,
that the LS7 would be in the 550-560 hp range.
Good luck with the sale, I'll be watching it.
Should be a pretty stout engine, no? Get a dyno run, that should generate some serious interest!
