Door Shim
Old Feb 12, 2007 | 05:18 PM
whitesnake81's Avatar
whitesnake81
Default Door Shim
Where can you buy Door Shims to take play out of a door and are they hard to install?
THANKS!
Old Feb 12, 2007 | 06:29 PM
Jc3vette's Avatar
Jc3vette
Corvette Central has them for I think $ 4.50 each. The bolts for the upper hinge inside the car are the hardest ones to get to on my 73 the rest are fairly easy. The attachment is from their web site.
Old Feb 12, 2007 | 09:59 PM
bondoboy's Avatar
bondoboy
If you have play in your door, you probably need new hinge pins and bushings. Shims just help line the door up.
Old Feb 12, 2007 | 10:33 PM
ford4play's Avatar
ford4play
i agree with bondoboy, but where actually is the play you are talking about
Old Feb 12, 2007 | 10:56 PM
Big2Bird's Avatar
Big2Bird
Shims are not wear absorbers. They are alignment devices.
Old Feb 13, 2007 | 10:37 AM
whitesnake81
It is in the up and down movement
whitesnake81
Thanks!
Old Feb 13, 2007 | 12:41 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Not shims. Hinge bushings and pins or loose hinges.
Old Feb 13, 2007 | 12:43 PM
whitesnake81
Thanks For Your Help!!
To Door Shim
