Correct color help....
Old Feb 13, 2007 | 11:22 AM
C486's Avatar
C486
Default Correct color help....
Ok, I need some advice on this....I have a very nice 71' coupe. However, it is black. According to my black book...it dosen't look like black was a color choice in 71. I need help in determining what the correct color for my car might be. The protecto plate is gone, I think that is what would normally would tell me the paint code, right? Any other methods to determine what color the car may have been originally? I can't seem to find much info just based on the VIN#. Any help this is greatly appreciated. Thanks in advance.
Old Feb 13, 2007 | 11:25 AM
Duke94's Avatar
Duke94
Should be a paint and trim plate attached to the left door hinge pillar.
Old Feb 13, 2007 | 12:39 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Duke94
Should be a ...trim tag attached to the left door hinge pillar.
You're looking for the trim tag and not necessarily the protect-o-plate.
Old Feb 13, 2007 | 03:54 PM
C486's Avatar
C486
Ok...looks like the trim plate is missing as well...Any ideas?
Thanks,
Matt
Old Feb 13, 2007 | 04:08 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Look in the wells behind the seats for the original color. Another way is to look under the rugs. Also you could pull the map pocket panel off the right side of the dash and see the original color there.
Old Feb 14, 2007 | 01:57 AM
PRNDL's Avatar
PRNDL
That's pretty unusual, but sometimes they do get removed. Here is a pic - with the driver door opened you can just barely see the trim tag all the way on the right side of the pic.
will try to find a better pic.
Old Feb 14, 2007 | 09:33 AM
Easy Mike's Avatar
Easy Mike
Pull a tail light. Unless a very meticulous repaint was done, you might find original color behind the tail lights. Some folks leave the lights in and mask them off when repainting.
To Correct color help....
