'72 LT1 or not?
Old Feb 15, 2007 | 09:12 AM
Mikeceli's Avatar
Mikeceli
Default '72 LT1 or not?
Hi folks, visiting from C5. I saw an add for a 1972 Coupe, so far photos only. Photo shows a SBC, painted orange tin valve covers, black dual snorkel air cleaner, air-conditioned, 4 speed. It has the "Big block" style hood.
How can I tell if it was an original LT1 Corvette? Do C3's have an RPO label/plate?
How can I tell if it still has it's original engine? Are block/head codes visable with engine installed? Thanks.
Old Feb 15, 2007 | 09:50 AM
Muddywaters's Avatar
Muddywaters
72 LT-1's have an L instead of a K within the Vin #. Muddy
Old Feb 15, 2007 | 11:25 AM
early shark's Avatar
early shark
As Muddy said, the vin tag will tell you if it was originally built as an LT-1 optioned Corvette.
Yes, the front engine pad is visible with the engine in place. You would be looking to see the assembly date with an engine suffix code of either CKY or CKZ, as well as the partial vin derivative. As far as whether it's original to the car or not, is not an easy task, get a knowledgeable individual to assist you in deciphering all the engine components to determine whether they appear to be the pieces installed at the factory.
Old Feb 15, 2007 | 12:20 PM
C3 4ME's Avatar
C3 4ME
although easily changed, LT1's would have finned aluminum valve covers.
Old Feb 15, 2007 | 12:26 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
And don't go by the big block hood...it seems at least on the CF that's a mod folks add to their small block non LT1 cars.
Old Feb 15, 2007 | 12:36 PM
GD70's Avatar
GD70
they also came with open element air cleaners, not dual snorkels, hirise aluminum intake and holly carb.
To '72 LT1 or not?
