Which CE frames are interchangable?
Old Feb 17, 2007 | 01:28 AM
gleninsandiego's Avatar
gleninsandiego
Default Which C3 frames are interchangable?
I have a 71 with a bad frame (bent in a wreck). If I could find another frame, what other years would fit? Any ideas on where I could find a frame and what it would cost? Any other options? Problem is, I am on a budget. (I know, corvettes and budgets don't mix)
Glenn
Old Feb 17, 2007 | 07:03 AM
Ganey's Avatar
Ganey
http://www.71corvette.com/frames.html
Old Feb 17, 2007 | 08:20 AM
parkerracing's Avatar
parkerracing
Good info!
Old Feb 17, 2007 | 10:31 AM
Artsvette73's Avatar
Artsvette73
You can go up to 73 without some major changes to the rear frame rails if you use a later frame 74 up. And you need to stick with an automatic if the car came with it vs. a manual.I used a 78 for my 73 like I said there was work to be done to the frame rails.
Old Feb 17, 2007 | 11:48 AM
wfo76's Avatar
wfo76
I think 69-73 also but the interchange manual says 69-74 will interchange?
Old Feb 17, 2007 | 12:45 PM
parkerracing
With basic metalworking skills a '63 to '79 can be made to work under any of those year bodies without alot of hassle. If you are doing a frame off matching number resto, disregard the above statement.
Old Feb 17, 2007 | 08:10 PM
72LS1Vette's Avatar
72LS1Vette
Glenn
Your budget should be at least $1,500 for a chrome bumper frame, probably more by now. I paid that for a frame back in Sept. 2006 and I'm sure the prices have risen since. If you find a good frame for a somewhat reasonable price jump on it. Since you are in Cal. there might be a better selection of good frames.
Rick B.
To Which CE frames are interchangable?
