EST Wire?
Old Feb 23, 2007 | 12:19 AM
Marcusk408's Avatar
Marcusk408
Default EST Wire?
Can someone tell me where the EST wire is on my '82 vette? I need to check my timing and the label on the hood says to disconnect the tan & black EST wire before checking timing. I don't see that wire anywhere.
Old Feb 23, 2007 | 12:41 AM
SIXFOOTER's Avatar
SIXFOOTER
should be on the distributor. I think some are in the same connector as everything else which means you need to cut it and put a quick disconnect connector on it
Old Feb 23, 2007 | 12:47 AM
Big2Bird's Avatar
Big2Bird
Probably along the firewall on the drivers side. Tan/blk tracer. Single black conn plug.
To EST Wire?
