Updated Serp System. (Pics.)
Old Feb 24, 2007 | 10:56 AM
Durango_Boy's Avatar
Durango_Boy
Originally Posted by Bee Jay
Just curious, is the serpentine belt more reliable or more durable than traditional belts. I only have an alternator, power steering pump, water pump, and crank pulleys. Could I change all of the pulleys to serpentine style, measure the loop, put a serpentine belt on, and use the alternator as the tensioner? It might even look cool. Do they make serpentine pulleys for my short water pump setup? I don't want to spend $500 for brackets just to run serpentine. I have a 96 truck engine in the garage I can raid pulleys off of.
Durango Kidd, I'm glad your getting work done, the engine looks good. You should replace one of those alternators with a supercharger, just a thought.
Bee Jay - First you can get the full set of brackets and accessories for $250 on Ebay all the time. That's how I got mine. I got two alts, power steering, pulleys, A/C, smog, brackets, mounting hardware, belt, and a few other goodies...for $250.
I think the serp pulleys could be adapted but you'd have a hard time finding a belt that short. The serp belt is not better per say except you only have one belt to change and you can change it in about 20 seconds with a 1/2" ratchet and the new belt.
The water pump pulley will fit the snout of the short pump just fine but you'd have to make a crank pulley that was shorter of use an LT1 style dampener where the balancer IS the pulley. It'd still be hard getting them to line up.
It's worth looking into, but you'd probably waste a lot of time and effort when you could just buy a serp kit like this one, install it, and go. You have an L88 hood and I'm pretty sure it'll fit just fine.
I am now not using my A/C delete, so you could have that from me, and all you'd need is the brackets, a CS alt conversion...which is easy, a newer model power steering pump, and MAYBE some frame rail clearancing.
Old Feb 24, 2007 | 11:43 AM
Bee Jay's Avatar
Bee Jay
No thanks, but what I thought would be a minor project, just turned into a major project. My alternator and power steering pump are fine, and my old fashioned V-belt is working fine. I guess this is one instance where "if it ain't broke, don't fix it".
Old Feb 24, 2007 | 12:01 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
A lot of time and effort for questionable gains. The old v belt system i think is actually more reliable. If you break a non critical belt you just keep driving. You have redundant belts if you have an A/C so if one breaks the water pump and fan still turns. In the case of an alt belt failure its easy to make it to the parts store on battery reserve (couple hours).
in the case of the serp if the belt brakes you only have minutes to overheating. And how else can you tell its gone????
Old Feb 24, 2007 | 12:36 PM
Big2Bird's Avatar
Big2Bird
The A/c could easily be added back.
Old Feb 24, 2007 | 01:46 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
I'm willing to be thats in TEXAS LOL
Old Feb 25, 2007 | 09:57 PM
VettePower's Avatar
VettePower
Speaking as a Texan. I would venture to guess that picture was taken in one of our Spanish speaking neighbor countries...... .
Old Feb 26, 2007 | 09:30 AM
Durango_Boy
Well the serp is all taken back apart so I could re-case the CS130s with chrome cases. They should look pretty sharp.
Old Feb 26, 2007 | 09:40 AM
CorvetteTechInc's Avatar
CorvetteTechInc
Matt, first time I saw this thread. The pulleys look great!!!
Sorry I didn't have time to read the whole thread. Do you plan to polsih/chrome/paint or powder coat them?
Old Feb 26, 2007 | 09:41 AM
Durango_Boy
Actually the post right before this one I indicate how I'm swapping the cases for new freshly chromed cases.
