Two post lift comments?
Old Feb 25, 2007 | 11:20 AM
Larry3x2's Avatar
Larry3x2
Default Two post lift comments?
I've got a Superlifts four post which is great for storage but needed a two post for drivetrain work etc. When I was at Barrett Jackson, Superlifts ran a show special so I now have a two post on the way. Does anyone else have a two post installed and what are some of the things I need to be aware of? The garage floor was already built with an 8" thick slab where the lift will be mounted.
Thanks,
Larry
Old Feb 25, 2007 | 11:35 AM
Durango_Boy's Avatar
Durango_Boy
Make sure your garage circuit breakers are up to the task of the needs of the motor plus whatever you already use in the garage. Did you make note of the motor and if it's designed for 110 or 220? When mounting it, give yourself enough room around the posts to walk around the car and even open doors when it's in the air or when positioning it.
Old Feb 25, 2007 | 11:53 AM
cub cadet's Avatar
cub cadet
Default lift
i am sure you know this already but here it goes anyway.when you are lifting whatever always lift with the 4 arms.say you just wanted to lift front to do tire work lift whole car or truck do not lift just one end.
Old Feb 25, 2007 | 11:55 AM
Durango_Boy
Also, if you're lifting up a C1 topless, keep the doors shut.
Old Feb 25, 2007 | 12:12 PM
OHIO69's Avatar
OHIO69
Be sure that the posts are plumb when installed. Usually accomplished using plastic horseshoe shaped shims between the base plates and floor. 8" of concrete is more than enough thickness. Since you will probably be using 5 1/2" - 6" wedge anchors, don't drill all the way thru the floor. Be sure to blow out the concrete dust from the holes before setting the anchors.
Bruce
Old Feb 25, 2007 | 02:12 PM
a560156's Avatar
a560156
Many of the manufacturers will do the installation for you. Are you going with asymmetrical design?
Old Feb 25, 2007 | 05:04 PM
JoeRags's Avatar
JoeRags
2-post asymetric here.... love it to death. Its from Autolifters of America, 8000 lb capacity, tested to 23,000.
My best advice is to ensure that whatever you buy is manufactured in the USA.
Pops and I got 'er installed in a day. Electrician was in the following day to wire it up... best investment we ever made.
Old Feb 25, 2007 | 05:21 PM
JoeRags's Avatar
JoeRags
Forgot to add... if you've got the ceiling clearance, definatley go with the clear floor option... very worth while.
Old Feb 25, 2007 | 05:41 PM
Larry3x2's Avatar
Larry3x2
Thanks everyone! I ordered an asymmetric floor plate model due to ceiling clearance. It's actually going into a new 30 x35 pole garage with a ten foot ceiling. I installed a 30 amp 220v circuit.
Larry
Old Feb 25, 2007 | 05:44 PM
JoeRags's Avatar
JoeRags
Larry
You'll love it... just be sure your hood is down when you lift the car!!!!!
Old Feb 25, 2007 | 07:31 PM
VettePower's Avatar
VettePower
What floor thickness does the manufacturer recomend?
Old Feb 25, 2007 | 08:03 PM
Godfathers Ghost's Avatar
Godfathers Ghost
And I don't know how significant it is but I was told by an experianced Vette guy once if lifting a C3 unlatch the T-tops first. I do just to be safe when jacking, since it can't hurt.
Old Feb 25, 2007 | 08:52 PM
Topless75's Avatar
Topless75
I know it isn't recommended, but does anyone store their car on a two-post lift? I need a lift for storage and one for mechanical work, but only have room for either/or...
Old Feb 25, 2007 | 09:04 PM
Durango_Boy
Four post lifts are better for storage. Some two post lifts are advertised as storage racks, but you must make sure the unit is set up for something like that.
Old Feb 25, 2007 | 09:06 PM
Topless75's Avatar
Topless75
I've seen (somewhere) a set-up that allows you to put full-length ramps on a two-post lift (called it "convertible")...but I can't find it.
Old Feb 25, 2007 | 09:18 PM
dfellinger's Avatar
dfellinger
Would appreciate info on this if anybody comes up with it.
Old Feb 25, 2007 | 09:54 PM
JoeRags's Avatar
JoeRags
Stored my fathers car under the vette on our two post for a few months... There's been some speculation about bushing damage that can occur. It was either that or let the 997 sit in the snow.
To Two post lift comments?
Old Feb 26, 2007 | 09:32 AM
Durango_Boy
If I had a two post lift, I would not store a car on it unless I had spoken with a tech support and made sure there would be no damage or safety issues with doing so. Like I said...some of them are designed for that.
Old Feb 26, 2007 | 10:51 AM
a560156's Avatar
a560156
I store a 3,000 pound car on a 9,000 pound lift. Install guys said no problem.
Old Feb 26, 2007 | 04:18 PM
Bee Jay's Avatar
Bee Jay
Unlimited ceiling.
