Starter grinds
Old Feb 28, 2007 | 01:51 AM
Marcusk408's Avatar
Marcusk408
Default Starter grinds
When starting my car, the starter sometimes grinds when I first turn the key as if the engine was already running. It will engage the flywheel ok after the 2nd or 3rd attempt. It would do this 1 out of 6 times. What's causing this?
Old Feb 28, 2007 | 02:23 AM
c3 in hawaii's Avatar
c3 in hawaii
It may have missing or damaged teeth on your flywheel.
Old Feb 28, 2007 | 04:17 AM
MJ355's Avatar
MJ355
u might need to shim it up
Old Feb 28, 2007 | 10:37 AM
Kyle69-71 BBs's Avatar
Kyle69-71 BBs
I would look at my flywheel if I were you
If its good...your stater may not be engaging properly.
Freespinning....look at the solinoid.
Make sure it is lined up straight to the block.
Bad sounds can come from a starter....it can also knock teeth off you flywheel if its misbehaving'
Is it on tight?
Does it do this at a cold start or just after its been run?
Old Feb 28, 2007 | 01:41 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
or misaligned or loose.............
Old Feb 28, 2007 | 04:41 PM
marshrat99's Avatar
marshrat99
This started happening on my 79 late last summer. I ran it for about 2 more weeks and then one morning the starter kept grinding but never did engage. Long story short is that the snout of my starter had broken in to
To Starter grinds
