I have a '72 with the 330HO (330 hp, 350 cu. in) GM crate engine. It has a Mallory Unilite distributor with mechanical advance only - no vacuum advance. It is set to add 24 degrees by 3,000 to 3,200 rpm, which seems reasonable, but I wonder why no vacuum?
Does anyone have any experience with mechanical-only advances? Why this over the ususal vacuum advance?
Jeff
Most of your performance engines dont use a VC can. As soon as you step on the gas your at full advance anyway. Conflicting statements about gas mileage as being poor with out the VC can is really not correct. Early FI engined Vettes never had them nor did the L88`s. My personal experience besides the racing engines that never used VC cans was with my FI Vettes and low ratios as per a 4.11 and at freeway speeds and above, 20 MPG was the average. Non vacuuum advance distributors were always dual point and considered a must for performance engines. Mallory was one of the first companies to mass produce them for every engine. We sold many of them for all makes.
