Adding AC?
Old Mar 1, 2007 | 10:28 AM
kipdog1's Avatar
kipdog1
4th Gear
Default Adding AC?
Has anyone tried to add AC to a C3 that was not factory equipped for air? I'm wondering how difficult and expensive it is? If anyone has experience with this, I'd appreicate hearing from you.
Old Mar 1, 2007 | 10:57 AM
gleninsandiego's Avatar
gleninsandiego
Do a search in C3 General for "vintage air" and a number of threads will come up. Here is a good one:
http://forums.corvetteforum.com/show...ht=vintage+air
Old Mar 1, 2007 | 11:04 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Do you want add-on air or factory air? I am putting the parts together for a factory air installation on my '68 with plans to convert to R134a as I go.
Do you have the assembly instruction manual? The AIM shows the entire factory air installation.
Old Mar 1, 2007 | 03:42 PM
snake321's Avatar
snake321
I have a 79 compressor that was working when I took it off a couple of years ago if anyone needs one..
Old Mar 1, 2007 | 08:44 PM
markdtn's Avatar
markdtn
I added factory a/c to a non-air car. You have to have the nose off and plug the air vent on the drivers side and add the flapper to the passenger side. I used a stock early inside box and an 82 outside box to get the cycling, orfice-tube system. You have to grind the fan housing just a little to use that evaporator box in a bumper car. Overall if I had a complete car, I would probably add a Vintage Air type underdash system.
Old Mar 1, 2007 | 10:07 PM
PinHead's Avatar
PinHead
I'm doing the exact same thing on my 71' with an 80' outside box etc. So far I've just collected the parts. But why do you have to take the "nose" (front clip?) off to do the conversion?
Old Mar 2, 2007 | 08:20 AM
Easy Mike's Avatar
Easy Mike
...I used a stock early inside box and an 82 outside box...You have to grind the fan housing just a little to use that evaporator box in a bumper car....
I'm using a '76-early box, inside and out. No grinding.
Old Mar 2, 2007 | 08:49 AM
markdtn's Avatar
markdtn
To plug the drivers side air vent, which you don't have to do. Also to add the max air flapper on the right side cowl. I don't see how you can do that with the nose on.
Old Mar 6, 2007 | 08:53 AM
kipdog1's Avatar
kipdog1
4th Gear
Default C3 Air Add On
Great advice. Thanks everyone.
To Adding AC?
