Can anyone identify the yellow one..??..not sure if it is for smallblock or big block....
I can, I've seen that one before. No doubt that it's definitely for a Hoover Wind Tunnel with the optional icemaker and spin cycle attachment. 4 slice of course, just to be clear on this so that it's not confused with the 2 cycle permanent press version.
what the real issue is that the overall perstate regulator is inducive to the way the threads of the screws are...... right handed screws are meant for adjusting the forwards motion of the cupler valve shutout t-stat unit while the left handed thread is use to adjust the emergency passenger ejection seat..... trying to set both at the same time will result in time-space rejection and hence all the work that you have done on the vette will not be directly proportionate to the overall in-direct time involved..... i can show a chart if needed
b
In other words, "Navigating an unsanitary tributary without the proper means of propulsion."?
