Vacuum hoses
Mar 2, 2007 | 11:06 PM
Vacuum hoses
Anyone ever hook one up to a CORVETTE carb adjusting screw ???
I did....
Rich
Mar 2, 2007 | 11:08 PM
Have you ever adjusted your vacuum?
Mar 2, 2007 | 11:11 PM
Quote:
Originally Posted by
Big2Bird
The one that takes gas fumes out of a vert ????
Rich
Mar 2, 2007 | 11:15 PM
rihwoods
Rich
No. The other one.
Mar 2, 2007 | 11:22 PM
Occasionally...
Rich
Mar 2, 2007 | 11:29 PM
Did you try replacing the vacuum in the lines?
Mar 2, 2007 | 11:36 PM
Yeah...used the shop vac...worked real good till I shut it off...Chilton's was not real clear on this....
Mar 2, 2007 | 11:40 PM
Haynes has more pictures of vacuum.
Mar 2, 2007 | 11:43 PM
I'll have to get one...my cigarette lighter keeps popping out of the socket...
Mar 2, 2007 | 11:45 PM
St. Jude Donor '05-'07
Mar 2, 2007 | 11:47 PM
DJ Dep
Have you ever adjusted your vacuum advance with that unit?
Mar 2, 2007 | 11:48 PM
DJ Dep
How often do you have to change the bag ??? I went thru 3 bags before I could change out all the vacuum in my 78...
Mar 2, 2007 | 11:52 PM
St. Jude Donor '03,'11
Mar 2, 2007 | 11:57 PM
rihwoods
Did you analyse the bag contents?
Mar 3, 2007 | 12:04 AM
rihwoods
It's bagless. But I get a ton of crap out of the hoses. If I hook it to my carb, the engine runs backwards.
Dep
Mar 3, 2007 | 12:09 AM
Big2Bird
Cheap bags..no port for a vacuum gauge...
Mar 3, 2007 | 12:14 AM
DJ Dep
Dep
Could you get oil pressure to 60 psi ?
Mar 3, 2007 | 12:19 AM
rihwoods
If you run the engine backwards with vacuum, do you still need an oil cooler?
Mar 3, 2007 | 12:26 AM
Big2Bird
That depends on whether you are driving backwards or not.
Mar 3, 2007 | 12:28 AM
Big2Bird
Not if you use cold plugs....or,as Dep said....drive backwards...
