Paging the VB&P rep
I just found something out regarding your concern if these are VB&P rods. A fellow forum member pointed out that his looked the same but were from mid america.
I just did a quick search and lo and behold
How the H did ecklers send these when VB&P smart strruts were ordered.
I think I have to go to ecklers to sort this mess out. There is nothing you can do for me. Sorry I called you out on it.
Does anyone know who supplies mid america with their adjustable struts?
Now the kit I installed came with the new center bracket with the revised pivot locations, this unit is a clearly a part of the vb&p kit. The mid america kit doesn't come with a bracket, this must explain why there are no shims for the poly ends (inside the camber bracket). the rods were packaged in a cellfoam box, the bracket was packaged in a small box by itself, and had, which I'm pretty sure of, a VB&P sticker on it
In the pic of the 72 trans am 455HO and the 80 turbo formula (only 1300 made) you can see the mach 1 also
that's why I posted them
Keep me posted on your progress.
Pattie
VBP
