Steering component removal
Old Mar 4, 2007 | 04:50 PM
tomard's Avatar
tomard
Default Steering component removal
I have a leaky Steering valve (coming out of dust cover) AND a leaky power steering cylinder (coming out around the rod) .... trying to remove them both, and not sure if I need special tool to remove the studs from the steering relay rod, but cannot get them off ..... I have a steering valve seal rebuild kit on the way to fix the leaky valve, but probably need to replace the cylinder, unless someone has a better idea.......
Anyone, with experience that can give me some advice ..... and maybe I need to hit autozone for some loaner tools, to make this a little easier?
Old Mar 4, 2007 | 06:05 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
A pickle fork will be helpful. Yeah, I've got a suggestion - hydroboost & trash the whole factory setup.
Old Mar 4, 2007 | 06:34 PM
Duke94's Avatar
Duke94
Check out this thread.
http://forums.corvetteforum.com/show...+valve+removal
Old Mar 4, 2007 | 07:59 PM
tomard's Avatar
tomard
Default Update
I got the Cylinder off by using a steering Tie rod puller ..... cannot get that same puller onto the stud of the steering valve though .... maybe a PITMAN arm puller (it is little more compact), or a ball joint seperator????
To Steering component removal
