Bead Blasting
Old Mar 6, 2007 | 09:49 PM
Chris Farrer's Avatar
Chris Farrer
Default Bead Blasting
I have heard the term 'Bead Blasting' on the Forum and when inquiring with the local Sandblaster he doesn't know what I mean.
Is Bead Blasting the use of glass beads, polysytrene, garnet stones etc or what substance.
Old Mar 6, 2007 | 09:55 PM
Big2Bird's Avatar
Big2Bird
Bead blasting is basically glass beads blasted within an enclosure.
It is also generally used to mean media blasting/visa versa.
Old Mar 6, 2007 | 10:14 PM
Chris Farrer
Thank you for the advice
Old Mar 7, 2007 | 10:45 AM
vettfixr's Avatar
vettfixr
I'll add one more comment. If your "local Sandblaster" doesn't know what bead blasting is I would find someone else. Quickly.
Old Mar 7, 2007 | 11:04 AM
rihwoods's Avatar
rihwoods
I use my friends blaster cabinet...the media is powder like...have done alum intakes,valve covers..it is very forgiving...sort of a light pink color...
I can call/get info,if needed...
Rich
Old Mar 7, 2007 | 02:16 PM
savewave's Avatar
savewave
CI 2-3-4-5-6-7-8-9-10-11-12
Wounded Warrior Escort '11
NCM Lifetime Member
Don't try bead-blasting paint off your fiberglas unless you know what you are doing -- otherwise you can put a texture on the glass that is difficult/expensive to remove.
Old Mar 7, 2007 | 04:07 PM
mooneyd's Avatar
mooneyd
Old Mar 7, 2007 | 04:23 PM
Chris Farrer
Thank you,
I want to use it the valve covers and air filter base.
Old Mar 7, 2007 | 09:10 PM
72LS1Vette's Avatar
72LS1Vette
There are several different types of blasting media available and each has a different purpose. You can look on Eastwood's website to get an idea of the different media types and their purpose. I agree that if your local blaster has no clue what bead blasting is you shouldn't trust him with anything delicate.
Rick B.
Old Mar 7, 2007 | 09:37 PM
TEXASDESERTVETTE's Avatar
TEXASDESERTVETTE
it is possible to use any thing from blow sand ....plastic media.... steel or lead shot...walnut shell ... ect.ect.... the type of media used and the size, will determine the cut rate...and finish desired... from a satin finish, to a heavy metalic flake look.... then if you intend to keep the desired finish...you will need to seal with clear or paint. ...or if you want it have a natural look just spray with a oil finisher wipe dry..and bang you are all set....this is a great way to hide surface blemishes...
as regards to sandblasters.....you most likely not find any living old blasters due to the lung health hazards....when you use a blast cabinet with worn out material...you see what I mean.
if you use a sand blast service and you want everything stripped..ask for a "white blast" and not the " commercial blast"...it will be clean and white.
Old Mar 8, 2007 | 01:43 AM
Sprzout's Avatar
Sprzout
I would wholeheartedly agree to this one...Bead blasting is commonly used to refer to using glass bead to blast your items. If the blasting service hasn't ever heard of it, I'd look for another service, and QUICK.
I've got a cabinet of my own, and I use either glass bead or aluminum oxide to strip...The glass bead tends to be a very soft material and works well for most of my smaller parts.
Old Mar 8, 2007 | 05:54 AM
hunt4cleanair's Avatar
hunt4cleanair
Rich
rih...are those valve covers for your 78? Did you paint them after beadblasting? I may be doing the same thing so curious.
Old Mar 8, 2007 | 10:03 AM
UKPaul's Avatar
UKPaul
It could be that it's known by another name in Aussie?
Chris, there's a bunch of people in your area who are into steam engine, railway & military vehicle restoration. If you can get hold of one of them they should be able to point you in the right direction.
To Bead Blasting
