Fire extinguishers
Old Mar 7, 2007 | 05:23 PM
427basketcase's Avatar
427basketcase
Default Fire extinguishers
Reading about some unfortunate experiences with fire got me thinking...
What are you (forum community) using for fire extinguishers that fit and work well in C3's
Any pics / ideas / recomended brands or suppliers?
Better to have and not need ..........................
Old Mar 7, 2007 | 05:25 PM
rabiddawg's Avatar
rabiddawg
I use a kidde foam extiguisher.
foam cuz its great for fuel fires
Old Mar 7, 2007 | 05:45 PM
miechesa's Avatar
miechesa
This place sells extinguishers/mounts www.vetteworksonline.com
Old Mar 7, 2007 | 05:57 PM
82MDVette's Avatar
82MDVette
That is where I'm buying my chrome unit with the seat bracket. What is the difference between the Halon and the Halotron?
Old Mar 7, 2007 | 06:10 PM
mayberg's Avatar
mayberg
Yea - wasn't it VetteDan here on the forum? Or am I confused?
That's the one I'm using. He put my pics on his website.
Old Mar 7, 2007 | 06:21 PM
427basketcase
Good link, That's exactly what I was looking for!
Old Mar 7, 2007 | 06:30 PM
saudivette's Avatar
saudivette
Foam makes a hell of a mess though. How bout Co2?
Old Mar 7, 2007 | 06:37 PM
Chris Farrer's Avatar
Chris Farrer
Thank you for the advice I have been looking too.
Old Mar 7, 2007 | 06:47 PM
saudivette's Avatar
saudivette
I just bought one of their brackets. Thanks for the link Paul
Old Mar 7, 2007 | 07:04 PM
alanbl's Avatar
alanbl
I've worked with all types of extinguishers as a volunteer firefighter for the last 18 years. You're right. Foam is a hell of a mess. So is dry chem. CO2 is pretty worthless - might do an initial snuff but the fire will usually come back.
Halon is the best. Will quickly put out most fires and does not leave any residue. I have two in the garage, one in the kitchen and one in my airplane (required.) You can order several sizes from:
http://sportys.com/pilotshop/
Old Mar 7, 2007 | 07:08 PM
Roscoe's Avatar
Roscoe
Old Mar 7, 2007 | 07:45 PM
Scottys78's Avatar
Scottys78
I just went to my local hardware store and bought a small one for a couple of dollars and put it in one of the compartments
Old Mar 7, 2007 | 08:00 PM
77BuffaloVet's Avatar
77BuffaloVet
I did the same...
Old Mar 7, 2007 | 08:05 PM
Roughrider's Avatar
Roughrider
I mounted extinguishers on the wheel well hump behind the drivers seat in each of my C3's. Just flip the release and they're out for use.
Old Mar 7, 2007 | 08:06 PM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
I researched this last year and decided I wanted the following attributes:
- Dupont FE-36 Halon replacement that is very effective and clean.
- 5 lb. extinguisher for sufficient volume
- A hose for accurate release.
I bought an Ansul Cleanguard FE05 from a local distributor and store it in the long rear compartment of my 81:
http://www.ansul.com/en/Products/han...cleanguard.asp
Old Mar 7, 2007 | 09:39 PM
Daytona69's Avatar
Daytona69
Old Mar 7, 2007 | 10:13 PM
82MDVette's Avatar
82MDVette
Good idea, thanks. Approximately what did you pay?
To Fire extinguishers
Old Mar 7, 2007 | 10:16 PM
kdf1986's Avatar
kdf1986
I have mine mounted on the front side of the passenger seat like Daytona69 has.
I made my own brackets to mount to the seat frame. I dont have the nice fire extinguisher like he has, but I opted for the cheaper version. I figure I rather have that than none at all.
kdf
Old Mar 8, 2007 | 02:00 AM
saudivette's Avatar
saudivette
I'll be buying one out here because of the weight and probable shipping restrictions. But you can still buy BCF out here...
Old Mar 8, 2007 | 02:39 AM
SEVNT6's Avatar
SEVNT6
I mounted mine in the right rear corner of the storage area....
