1976 electrical problem
Old Mar 7, 2007 | 05:34 PM
ovgolfer's Avatar
ovgolfer
3rd Gear
Default 1976 electrical problem
Almost finished with car then started on dash replacement, now have no power to dash lights, cig lighter clock or interior lights, fuses look good. Does anyone have picture of fuse panel showing showing where the extra connections plug in ? There are a few plugs not connected hanging around fuse panel. I have several manuals and wiring book but they are no help.
Old Mar 7, 2007 | 05:51 PM
SIXFOOTER's Avatar
SIXFOOTER
check power on both ends of the CTSY fuse, sometimes it Looks ok, but not making good contact in the fusr clip
Old Mar 7, 2007 | 06:43 PM
Duke94's Avatar
Duke94
Check the main dash ground on the left windshied pillar just above the door hinge.
Old Mar 7, 2007 | 10:34 PM
seventysixvette's Avatar
seventysixvette
At least in as far as I'd check the grounding out throughly.
Get a nice piece of #12 wire 'bout 10 foot long. Go to a car or electronics parts store. Buy a alligator clip large enough to clamp onto a battery terminal. put a smaller clip on the other end. Clip the large clip to your NEGATIVE battery post. Simply clip the other end to the metal frame work on your instruments. This bypasses any open shorts, loose bolts or corrosion problems
I had some problems under hood when I first got my '76. Wipers, heater fan didn't work right, fan ran very oddly. Turned out it was all grounding. The + supply was just fine.
John
Old Mar 8, 2007 | 06:02 AM
ovgolfer's Avatar
ovgolfer
3rd Gear
Great advice on grounding, any ideas on where fuse panel plug ins go ?
Old Mar 10, 2007 | 03:25 AM
ovgolfer's Avatar
ovgolfer
3rd Gear
Repaired, Hired auto electrician. AKA small flexible guy with knowledge. The problem was fuse,socket,bulb related. While he was under dash replaced all fuses. Thanks to all who sent advice. I hope to get it back together by next weekend.
To 1976 electrical problem
