uh oh....
Old Mar 9, 2007 | 10:47 AM
Big2Bird's Avatar
Big2Bird
I wouls start there. Ground the lead, it will read full. If it does, pull the sender.
A)Sender
B)Float
C)Tank half full of epoxy resin
Old Mar 9, 2007 | 10:54 AM
JoeRags's Avatar
JoeRags
A)Sender
B)Float
Tank is new... no epoxy. Sending unit is new... but could still be broken.
I'll be looking into this over the weekend.
Old Mar 9, 2007 | 05:51 PM
GTR1999's Avatar
GTR1999
Joe,
Check the wire connector on the bottom of the tank for being loose corroded. Pull the wire off the sender and turn on ign. The gauge should peg out past full. Ground the wire and the gauge shodl go to below E. If the gauge doesn't move check power to it or replace the gauge. If it was ok then just stopped look for loose fitting sender connector. See driving in CT salted roads!
Who did you use for the top?
Old Mar 9, 2007 | 07:04 PM
JoeRags's Avatar
JoeRags
Originally Posted by GTR1999
Joe,
Yea... that how salty the roads are! I'll do those checks tomorrow. See what the problem is. Ray up at Corvette Center did the top, it came out very nice. I need to give the car a good scrubbin tomorrow, so I'll take some pictures.
