Brake Rotors Riveted On?
Old Mar 9, 2007 | 06:00 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Default Brake Rotors Riveted On?
Putting brake pads on the '71 today for the first time, and it looks like the rotors are riveted to the hub assembly?
They're in great shape (no turning required), so it's not a big deal. I just wasn't expecting that.
Old Mar 9, 2007 | 06:06 PM
SEVNT6's Avatar
SEVNT6
That means they have never been off or someone re-riveted them. Which never happens...............
Old Mar 9, 2007 | 06:26 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Search will tell you more than you ever wanted to know about those rivets.
Old Mar 9, 2007 | 06:37 PM
427-390's Avatar
427-390
You ain't a-lyin!
Old Mar 9, 2007 | 06:51 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
They definitely appear to be original (88k miles). Thanx. I now see all the posts about rotor rivets.
Old Mar 9, 2007 | 06:54 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Sounds like a pretty original car. My fronts were drilled when I got my car. The rears, I had to drill to get them off.
My car was well used when I got it though.
Old Mar 9, 2007 | 08:44 PM
Durango_Boy's Avatar
Durango_Boy
You don't have to remove them if you don't want to but it would be a good idea to check for runout. If you don't know how to do that a good brake shop should.
When the bearings wear the wheel...wobbles...and that's runout. That can lead to a lot of problems including pitting inside the brake caliper's pistons, and excess air being sucked into the lines.
It's just a good idea to check...plus you'll know how good the condition of your wheel bearings is.
To Brake Rotors Riveted On?
