Tires
Old Mar 11, 2007 | 06:18 PM
SULLY_PA's Avatar
SULLY_PA
Default Tires
I have a set of Dunlop gt qualifiers 25560r15's on stock wheels at the moment and read that the suggested rim width is 7"...Was wondering if I could put them on a 6" width without problems....
Old Mar 11, 2007 | 07:13 PM
StickShiftCorvette's Avatar
StickShiftCorvette
Most people run that size on the stock 8" rims without problems. That was a standard size with the factory aluminum wheels on C3s.
6" rims might prevent the tread from laying flat on the road.
Old Mar 11, 2007 | 07:33 PM
Roughrider's Avatar
Roughrider
7" is the minimum recommended width for that size tire. You may be able to fit in on a 6" wide rim but you'll have premature tire wear and heat buildup that can lead to tire failure and possibly ride and handling issues.
Old Mar 11, 2007 | 07:40 PM
SULLY_PA's Avatar
SULLY_PA
Thanks thats what i figured ...guess I'll let the cragars I found cheap go....
Old Mar 11, 2007 | 08:32 PM
dgruenke's Avatar
dgruenke
Those should really be on 8" rims. They won't wear right on 6".
To Tires
