Gut less wonder…..
Old Mar 12, 2007 | 02:59 PM
88turboGT's Avatar
88turboGT
Default Gut less wonder…..
Snow finally melted and got a chance to drive the 81… for the first time since getting it.
I got a stark reminder…. of when I used to smoke these things from the light with my 79 turbo 2.3 Mustang…..
I have to say numbers matching….who gives a Rats A**! What a boat anchor…..
Looks like the shark gets the DZ 302 motor a little faster than the wallet can afford…
I can’t stomach this for the whole summer….. Bust out the Credit Card…..
Old Mar 12, 2007 | 03:25 PM
SIXFOOTER's Avatar
SIXFOOTER
No need for a whole new motor;
AFR180 heads
Headers
nice cam
Old Mar 12, 2007 | 04:47 PM
88turboGT's Avatar
88turboGT
AFR180 heads
Headers
nice cam
Would that get me at least 16's or 17's in the quarter.....
I bought the car to put the motor in anyway.... but it just looks like a sports car and does not run like one... Then again.... those were not Detroit finest hours.....
Old Mar 12, 2007 | 05:03 PM
panic's Avatar
panic
Originally Posted by 88turboGT
I bought the car to put the motor in anyway.... but it just looks like a sports car and does not run like one.....
you'll need a new engine, new brakes, suspensions and get rid of about 600/700 lbs of overweight...then you'll have a vette that will run like it looks...
Old Mar 12, 2007 | 05:10 PM
Z-man's Avatar
Z-man
While you're at it, toss in a supercharger...
Old Mar 12, 2007 | 06:42 PM
88turboGT's Avatar
88turboGT
Well I thought about that too!
But might not work so well with the 11.9 CR in the DZ motor.
Also thought about turboing the crappy L 81......Nhaaaaaaa!
New motor trans and rear end.... and I'm on my way....
Old Mar 12, 2007 | 07:39 PM
Star79's Avatar
Star79
If your car is THAT slow, then there's something wrong with it. Even the 305 CI California version did 16's stock.
You can go ahead and throw crazy money at a new motor, but headers/heads/cam will get you nearly as far for a lot less $$$.
Old Mar 12, 2007 | 08:09 PM
Gordonm's Avatar
Gordonm
If you are that worried about performance why are you only going to use 302 cubic inches. That is a tiny motor by todays standards. At least put in a stroker or better yet if you want some high HP go with 502+ cubic inches. A decent built Sb or BB will still smoke a 302 equipped Vette.
Old Mar 12, 2007 | 08:11 PM
LemansBlue68's Avatar
LemansBlue68
Sell the DZ302 to a guy restoring his '69 Z-28 and use the proceeds to build 383 (minimum) small block. The DZ motor was a fine motor for what it was intended, i.e., homologate the Z28 for trans-am racing, but it was displacement limited and low on low end torque. I know, I used to have a '69 302 Z28. There's no replacement for displacement. Besides, if your '81 is an auto, the DZ302 won't like it and it probably won't like the low rear axle ratio that likely came in your '81 either. The early Z's were sold only with 4 speeds and steep rear axle ratios for a reason.
Old Mar 12, 2007 | 08:20 PM
72LS1Vette's Avatar
72LS1Vette
If you have the bandwidth on your credit card go the LS1 - LS2 - LSX route.
Rick B.
Old Mar 12, 2007 | 08:42 PM
88turboGT's Avatar
88turboGT
Yes…. I see your point …. The motor came out of a 69 Z. No resto rocker would want it because it’s far from stock. I.E Pistons, crank, rods, heads or cam. Last car it was in was a 66 Nova. 2,800 lbs and ran 10.63s with a 2spd slip n slide.
Everyone and their brother is running a 383 or similar. Kinda like saying I have a 350 Camaro….. big deal me and 20 million other people.
I had a 69 mustang with a 302 and it ran 12.50s all day long. I like high revving small blocks.
I k now this is going to spark a ton of bench racing….. but you can go fast on less cubes…. I’ll race you’re Chinese rotating assemblies…. Any time.
The replacement for displacement is Nitrous or forced induction. You just need to be smart about it that’s all.
I’m getting old wanting one of these boat anchors… when I was younger… they were just Disco buggies…. Now I like them….doooooooh I’m old!
May need some recommendations for diff work and such though.
Old Mar 13, 2007 | 10:39 AM
mpett1's Avatar
mpett1
If you already have the motor put it in......Gear it low and blast off...
Old Mar 13, 2007 | 11:15 AM
mod81's Avatar
mod81
yep i'm thinkin something could be wrong...my 81 runs like champ and all I've done is cut off the smog crap and put on a good exhaust. Its probably a 15 second car, plenty for a 22 yr. old to drive since i get pulled over every other trip anyway.
Old Mar 13, 2007 | 11:32 AM
ghoastrider1's Avatar
ghoastrider1
here you go,complete 1998 c-5 running gear for $6,500. Thats trans,motor and rearend.driveshaft.
http://auto-rv.com/browse.aspx?AdName=8-324876
Old Mar 13, 2007 | 01:38 PM
88turboGT's Avatar
88turboGT
I wonder if they take plastic????
Old Mar 13, 2007 | 04:36 PM
Clint's C3's Avatar
Clint's C3
I was tired of driving a boat anchor, too. I started with a L-83 CFI. Edelbrock heads, cam, intake and Holley 670 got me to the 9.0s in the 1/8. W/ nitrous turned an 8.44 and didn't shoot until 3500 rpm. This is equivalent to very low 13's in the 1/4. I tried to shoot off the line but my street tires almost melted. Total cost was < $3000.
You can read this link for details. Good luck.
http://www.crossfire.homeip.net/cfte...ID=18&CAT_ID=1
Old Mar 13, 2007 | 07:00 PM
dgruenke's Avatar
dgruenke
Not much of a challenge there.
Then do a 396.
To Gut less wonder…..
Old Mar 13, 2007 | 07:13 PM
OregonVette80's Avatar
OregonVette80
Not really, if you look at the other cars it was competeing against:
FOR THE RECORD:
1980 Corvette
It was faster than a Porsche 928 and less $
It was much faster than the Ferarri 308 and MUCH less $
You already sound mechanically inclined so,
Put on headers, nice aluminum AFM heads, decent lumpy cam and a carb/intake manifold and you're back where you want to be. That's the beauty of these small block chevy's.
You can do the exact small block gig as you did with your ford...but for a lot less MONEY!
Not to mention, from an engineering standpoint, there are many engineers who will suggest the SBC is one of the most efficient powerplants designed.
(please know, I come from a long line of FordFanatics in my family) My first car was a 66 Galaxie. Then a 67 Mustang. Then a 1970 Ranchero GT (wicked fast 351C). Then a 1980 Mustang, Then a 1988 Mustang, then a 1970 Comet GT (crazy hot 302SBF)....
But they were all ugly as turds...I started approaching the big FOUR OH (aka 40) and the crazy stingray Vettes started looking cool to me. So I got one
AP
Old Mar 13, 2007 | 10:23 PM
88turboGT's Avatar
88turboGT
FOR THE RECORD:
1980 Corvette
AP
I know what you are saying I hit 40 and the disco buggies started looking better and better.
Some of those Fords I think are good looking... but thats my opinion.
The American way has always been if it doesn’t run good add more cubes. Yet they complain about getting spanked by a turbo Neon….
IMHO anyone can make cubes and power…. but making power on less is the real challenge.
I have $1,500 into the 302. Removed the solid cam put a HFT cam in to flatten out the PB…. and I’m on my way. Shift at 7K and call it a day.
To move 2,800 pounds in the quarter like the 302 did…. It takes about 430 hp. No dyno runs but the math should be close. Why should I put a Chinese rotating assembly into a 350 block to get about the same power? Torque will get the anchor moving but HP will keep it alive at traps.
I’m surprised that people still think they can build a Chevy for less. Pick up a Summit cat and compare heads for heads… since the popularity of the 5.0 has dropped prices drastically.
Also what are your thoughts about spending money on a crappy 2 bolt L 81 lower end???
I don’t get it?????
I’m assuming that the L81 has cast pistons in it???? If so can’t squirt much nitrous into that!
Maybe I’m just old school……
Old Mar 13, 2007 | 10:34 PM
88turboGT's Avatar
88turboGT
Clint
I hear ya brother..... Are you spraying cast pistons????
Nice lookin motor too! Keep up the good work.
