power steering keeps leaking?
Old Mar 14, 2007 | 09:15 PM
whoodiestyle's Avatar
whoodiestyle
Default power steering keeps leaking?
ok well i have had the return line i guess thats it replaced for the 3rd time and its leaking again what gives? do i need a better hose or what?
Old Mar 14, 2007 | 09:53 PM
stock76's Avatar
stock76
Maybe it is a pressure problem. Did you replace the power steering pump recently? C-3 Corvettes require a lower pressure flow control valve. It is recommended that you use the old control valve out of your old pump when replacing your existing pump with a new one. The whole system works off a lower pressure than other GM cars that use the same interchangeable Saginaw pump. A rebuilt or replacement pump could come with the higher pressure flow control valve that is wrong for the C-3s system.
I'm not sure if that would cause a new hose to leak so soon. Go to www.corvettefaq.com and take a look at the steering papers written by Jim Shea. That may help. Maybe he will see your post and jump in with some expert help.
