since someone brought up bezels..
Old Mar 15, 2007 | 12:32 AM
vettlibito's Avatar
vettlibito
Default since someone brought up bezels..
It seems where ever I look they say the din bezels are die cast.. does that mean aluminum?... I want to buy one and customize it for my 76' So I prefer plastic. When I go home I want to start customising my interior... OH, and what has everyone been doing when it comes to customising the shifting console area... I want it to have the AC controls, the shifter (of course), and then a brand new lighter plug.. no ash tray...
As for stuff I am already going to do.. I am buying Corbea A4's.. I got the engraved sill plates that say "Corvette". The lloyd floor mats that have the flags... and then I have a few ideas that I am still pondering.. But I'm single again.. so no distractions from the VEtt..lol
exterior wise as of now when I get back I am getting the 2.5"wheel adapters and the C5 Zo6 rims..
Then in the future when I get to hawaii I am going to buy all the fiber glass i need and replace my fiberglass along with a new paint job.. YEAH!!!!
Old Mar 15, 2007 | 09:25 AM
Duke94's Avatar
Duke94
YEAH!!!!
Most of the older diecast parts are Zinc.
Old Mar 15, 2007 | 09:30 AM
GD70's Avatar
GD70
My headlight bezzles are fiberglass and all the vendors sell fiberglass. Have never seen aluminum ones for sale. Are they still out there.
The COVERS are aluminum.
Glenn
Old Mar 15, 2007 | 12:09 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by GD70
My headlight bezzles are fiberglass and all the vendors sell fiberglass. Have never seen aluminum ones for sale. Are they still out there. The COVERS are aluminum.
Glenn
Actually, they're pot metal. Not pure aluminum, but still very light. I've seen the pot metal bezels (early cars). They weigh about as much as the fiberglass versions.
Old Mar 15, 2007 | 12:31 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
Glenn
I know 68's and 69's had pot metal bezels, 69's had the squirter holes. I think they may have used metal up to '72?
Old Mar 15, 2007 | 01:24 PM
vettlibito's Avatar
vettlibito
anyone know where i can get myhands on a fiberglass or plastic gauge cluster bezel for my 76?
Old Mar 15, 2007 | 02:45 PM
seventysixvette's Avatar
seventysixvette
Here's a link to a thread that might help. It's not a plastic guage bezel, but it helps!
John
http://forums.corvetteforum.com/show....php?t=1539559
Old Mar 16, 2007 | 08:51 AM
Easy Mike's Avatar
Easy Mike
76? There isn't a plastic bezel. They're metal. Plastic cluster bezels came in for '77.
Old Mar 16, 2007 | 10:44 AM
kortensi's Avatar
kortensi
Well I dropped a box on my bezel and broke it in half.
Is there a way to put (weld/reattach) it back together?
PS: MIG didn't work
KO
Old Mar 16, 2007 | 10:54 AM
vettlibito's Avatar
vettlibito
would the 77 bezel fit in my 76.. they all look the same to me...
Old Mar 16, 2007 | 11:31 AM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
PS: MIG didn't work
KO
I just had 2 welded for my 68, I know nothing about welding, but the guy told me he used a special stick designed special for the junk pot metal. I know it welds at 350 degrees, as opposed to 700 degrees (?), he said it's a TIG. also, if you GOOGLE "welding pot metal" a web site sells the stick and actually has videos of the guy welding die cast pot metal bezels (not Corvette). JB Weld will not work (tried it), Good luck, John. also, these are pretty easy to find on EBAY at reasonable prices.
Old Mar 16, 2007 | 11:33 AM
Ganey's Avatar
Ganey
The 77 bezel would fit to the dash on earlier years however some mod. would need to be made to fit to console. The 77 console was changed also.
Old Mar 16, 2007 | 04:26 PM
early shark's Avatar
early shark
Glenn
The headlight bezels are metal from 1968 thru 1972. However 1968 had running changes to the headlight covers in shape/size and possibly the bezels as well. The 1969 & 1970 used metal bezels which had provisions for headlamp washer squirters, there was also a running change during '70, as the lower squirter hole moved from the horizontal plane to the vertical plane surface.
Yes, you do see them occasionally on ebay vintage parts for sale category and run across them also at Bloomington and Carlisle Corvette swap meets.
Old Mar 16, 2007 | 09:08 PM
LemansBlue68's Avatar
LemansBlue68
The early headlight bezels ('68-72) are cast aluminum. Nothing else. Zinc die cast would be considerably heavier for the size. '73 and later are fiberglass. The fiberglass ones are still comonly available. The cast aluminum ones are much more difficult to find, especially considering the hole configurations (or lack therof, if that's what you need) for the headlight washer nozzles, so expect to pay much more for these.
If you're talking about the console bezels, THOSE are zince die cast.
Old Mar 17, 2007 | 02:02 AM
Sprzout's Avatar
Sprzout
Odd that you say JB Weld doesn't work...I have several parts on the Vette (including a bezel) that have been JB welded, as well as a thermostat housing on our '67 Jaguar E-Type that is pot metal. They seem to be holding really well together. Then again, I used the JB "Industro" weld, which is a different epoxy compound mix than the regular JB Weld mix (it takes 24 hours to fully harden). How did you JB weld it? Did you brace the welding, prep the pot metal areas so it'll adhere better, let the JB weld set up a little bit before you tried to smear it on?
And TIG welding requires a welder that is going to cost in the neighborhood of $1800, plus that special stick that you're talking about. For that price, you can get several bezels. Cost wise, it's not that effective.
Old Mar 17, 2007 | 09:04 AM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
You're right, I used the reugular JB Weld. It held for a little while, but snapped at the original breaking pont when installed. As far as the TIG wels, i'm lucky to have a contract with a weld shop that outfit some of my equipment. The TIG weld cost me 0$, but the sticks cost about 15$ per, so If you find a decent shop, it shouldn't be expensive. Also, most of these bezels crack at the "thin" point, near the wiper bezel. Depending in where it breaks, and obviosly how clean of a break, will determined how good the repair will be. A vendor at Carlisle selld these "restored". They're really nice and he gets about 600$ for one, especially if it's a 68 (smooth). I found one last year that was cracked on one side only, at the thin point. He was not interested in it at all, said 'no one can fix these"....I guess that's why I abandined the JB Weld, considering it didn't work for me, and I was certain anybody attempting this from home would try this first. That's why I went to the TIG......hey whatever works for you, THanks, John
Old Mar 17, 2007 | 09:11 AM
saudivette's Avatar
saudivette
Here's a metal one...
http://cgi.ebay.com/ebaymotors/72-73...95032726QQrdZ1
I don't think the '77 bezels fit without some modification. Also, I think the bezels in the '76 had all round holes for the gauges whereas the '77 only has the round hole for the clock, all the others are flattened off on the bottom...
Old Mar 17, 2007 | 09:14 AM
saudivette's Avatar
saudivette
Hmmm... the bezels in my '82 are aluminium, definitely not pot metal
Metal ones are still available tho...
http://cgi.ebay.com/ebaymotors/68-69...spagenameZWDVW
To since someone brought up bezels..
