'70 EEC system..???
Old Mar 17, 2007 | 03:42 PM
jim2527's Avatar
jim2527
Default '70 EEC system..???
My '70 base engine has no EEC/vapor lines running down the drivers side frame rail. There is no canister in the drivers fender.
Looking in Paragons website it apperas not all '70 cars had the EEC/vapor system. can anyone shed some light on this.
Anyone have schematic of the PCV valve and tubing for my car?
Paragon part # 3572K
Please do me the favor and tell me my car didnt come with it....!!!!
'70, 4sp., base 350, A/C
Thanks,
Jim
Old Mar 17, 2007 | 03:54 PM
7T1vette's Avatar
7T1vette
I believe the '70 had about the same emissions equipment that is on my '71. PCV valve and vapor return line/cannister are parts of that. Simply put, there is a vapor recovery line from the cannister to a "T" fitting going to the PCV valve. The PCV fits in a hole on the left side valve cover. The outlet side of the "T" fitting goes to a vacuum connector at the base of your carb. (That's were the oil & gas vapors get sucked into the intake manifold.)
Old Mar 17, 2007 | 07:00 PM
jim2527's Avatar
jim2527
I have a PCV valve but nothing else. In my quest to rid the garage of fumes I discovered there's nothing pertaining to an EEC/cannister system on my car. That in turn lead me to the Paragon site looking for parts. I noticed they list some '70 models that may not have an EEC with the cannister. I trying to figure out if my car is one of them or if someone hacked it.
Jim
Old Mar 17, 2007 | 09:30 PM
7T1vette's Avatar
7T1vette
I don't know when the vapor cannister went into effect in '70. I do know that there was a strike in Sept 69-early 70, so maybe it was a "pre-strike" and "Post-strike" change issue. Keep researching...I'm sure someone on the Forum can clear this up.
Old Mar 17, 2007 | 09:51 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...I maybe wrong on this, but the tune-up label(if original)behind your master cylinder/brake booster should say "EEC" if your car had/has it. I know the 1973 and up labels do. They'll list A.I.R. for the smog pump, EGR, EFE, OOC(catalytic converter)for the later C3s.
Old Mar 17, 2007 | 10:39 PM
early shark's Avatar
early shark
The 1970 Corvette models destined for California had the NA9 additional emissions. I believe this included the Evaporative Emissions Control (EEC) that you are talking about. 49 state 1970 models didn't need it.
Old Mar 18, 2007 | 02:13 AM
Z-man's Avatar
Z-man
Unless the car was sold in CA, the extra stuff wasn't on them. We used to have a term - "49 State" cars....
Old Mar 18, 2007 | 08:30 AM
jim2527's Avatar
jim2527
Thanks for the help. I'm liking this '70 more and more as I go. High compression, no A.I.R. system, no EEC and no expansion tank. Nice and clean under the hood.
I'm still waiting for my reference books. Does anyone have a PCV scematic for my car?
Jim
To '70 EEC system..???
