New engine build (Pics)
Old Mar 19, 2007 | 11:43 AM
my2nd78's Avatar
my2nd78
Default New engine build (Pics)
I have a thread for the whole front suspension rebuild and motor, but I thought that I would start a thread specifically for the engine build. I had forgotten the camera when I installed the crank. So far I have installed the crank bearings, checked the crank tolerance and then installed the crank. I then set the ring gaps and installed the rings. Next I installed the rod bearings and pistons. check out the piston install tool. It is way faster than the adjustable tool. I will take more detailed pics going forward. If anybody has a request for a specific picture let me know.
Crank installed, along with #1 and #2 pistons in their bores
Piston and rings
New tool
Old Mar 19, 2007 | 11:45 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Keep the pics coming!
I'm currently doing my first engine build and can use all the help I can get.
Old Mar 19, 2007 | 11:56 AM
my2nd78's Avatar
my2nd78
I'm going to try and get as many pics as I can. It can be difficult to grab the camera with oiled and lubed hands. It's the wifes camera.
Old Mar 19, 2007 | 12:44 PM
78pacer's Avatar
78pacer
What specs are you rebuilding it to? My L-82 is coming out soon. looking for ideas.
Mike
Old Mar 19, 2007 | 01:19 PM
my2nd78's Avatar
my2nd78
Mike, Nothing radical on the build, it's the wifes car. It should have good low end torque. I just hope she can keep it in a straight line
Dart heads 170cc, 67cc
Edelbrock Performer
Keith BLack Flatops
Roller Rockers 1.5
Crane Cam 272
Block is 30 over now
Original Q-jet
I need to get it all bolted together before I change my mind and start making more modifications.
Old Mar 19, 2007 | 01:22 PM
Scottys78's Avatar
Scottys78
Old Mar 19, 2007 | 06:56 PM
78pacer's Avatar
78pacer
Very nice, any idea of the hp you'll achieve with that combo?
Mike
Old Mar 19, 2007 | 07:19 PM
Roscoe's Avatar
Roscoe
Great Pictures
Old Mar 21, 2007 | 08:45 AM
my2nd78's Avatar
my2nd78
Thanks everyone. This has been a lot of fun.
I haven't run the numbers for HP. There is a dyno across the street, so I will be headed over there to tune and check the numbers.
I got a little more done last night. The cam is in and the time is set along with the oil pump installation. I forgot to grab the oil filter housing so that stopped me from putting on the pan.
Chris
i put a mark on the crank referencing the old gear mark just to make sure things looked "right" with the new gear.
Set the cam in place and lubed
I was trying to get a pic of the marks lining up when #1 was up.
Old Mar 21, 2007 | 09:25 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
looks good
don't forget the lower oil dipstick tube before you install the pan. I have one extra because it doesn't fit my later style block that has a longer 1pc dipstick tube. Let me know if you want it.
And weld that pickup to the pump so it won't come off
Old Mar 21, 2007 | 10:47 AM
my2nd78's Avatar
my2nd78
MYBAD, Thanks for the reminder. I will weld that pickup in place Friday. I think I have a new dipstick tube. I'll have to check and let you know. Thanks for the offer.
Chris
Old Mar 21, 2007 | 01:42 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Chris
PM or email me if you want it.
That lower tube does not come with the chrome tubes that you can get at the part store. I had a hard time finding one, finally I found it on Ecklers website. When I received it I noticed that it doesn't fit ... then I couldn't find a longer dipstick tube for the newer blocks anywhere, had to order that from a Chevy dealer...
Old Apr 9, 2007 | 01:13 PM
my2nd78's Avatar
my2nd78
Heres a little Monday pick me up. I've had camera issues so I've missed a bunch of progress picks. Here it is ready for install. I put the headers on so I could get the plug wires run and make sure that everything lined up correctly. I don't want to have to struggle with stuff when the motor is in the car. I still need tofind valve covers and I think I am going to by the Accel corrected dist cap.
New Home
Old Apr 10, 2007 | 08:54 AM
jimvette999's Avatar
jimvette999
nice work!! That's a good looking engine
Old Apr 10, 2007 | 09:01 AM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Good thread.....I am doing my 454 now and am curious????
What type paint did you use in the "valley".....?
Thanks.....
Old Apr 10, 2007 | 09:08 AM
Jims79's Avatar
Jims79
Looks great, thanks for the class. keep the lessons coming.
We should save all these how-to-threads in a "how-to-section" They would make a great referrence guide.
Old Apr 10, 2007 | 12:50 PM
Kid Vette's Avatar
Kid Vette
Thanks for this thread and all the pics! Its nice to see a simple information sharing thread on this forum again.
Old Apr 10, 2007 | 02:34 PM
jackson's Avatar
jackson
Dunno? ... pics can lie ... but looks like typical chevy orange engine enamel ... rather than the preferred "GLYPTAL" brand which is a much darker brick red-brown.
Old Apr 10, 2007 | 02:45 PM
my2nd78's Avatar
my2nd78
Thanks everyone. I hope to have the trans on tonight and back in the car and running shortly there after.
fotyfo rustoleum is the old school way to go as I was told. Most don't bother with the valley. Nobody would know if I had painted the valley or not, but it was the right thing to do.
To New engine build (Pics)
