Why did Chevy do this??
Old Mar 22, 2007 | 08:40 PM
CCrane65's Avatar
CCrane65
In 72 they used the same dual snorkel air cleaner for the base 350 as they used for the 454.
cc
Old Mar 22, 2007 | 09:25 PM
Red81Shark's Avatar
Red81Shark
Cruising
i've got an '81 with a dual snorkel.
Old Mar 23, 2007 | 07:31 AM
rweasterly's Avatar
rweasterly
i have a 77 with a 74 hood and cowl working setup with a 80,s air cleaner dual snok base and the over the radiator intake and the 74 top and seal....it looks like the car looking like it came that way.(in other words its not a "hot rod" look) if thats what u want...i kinda wanted a semi stock look..i also think the cowl induction was a very good set up....untill the fed got incolved.....also there is so much heat under the hood of our vetts that i think it fresh air is good....
Old Mar 23, 2007 | 01:06 PM
copter's Avatar
copter
We all know about the 82 aircleaner.It is a ram air set up with a flapper door connected to a seloniod so when you floor it it opens and you get 100 hp extra I took my flapper door off and have it put away.
Old Mar 23, 2007 | 01:48 PM
Jc3vette's Avatar
Jc3vette
Originally Posted by dosoctaves
73-75 Cowl setup is the best setup for cold air..after you remove the flap mechanism so that it is always open. Cold air in the top and forced out the snorkels which also help cool the engine compartment.
This set up would be even better if we could get K&N to make a Xstream lid for our 12" filters. I ask them about it and this was there reply.
Hello,
Thank you for your interest in K&N products. I am sorry to say at this time K&N does not have anything in the works for an Xstream lid for a 12” filter
