What would keep my secondaries from opening...
Old Mar 26, 2007 | 06:47 PM
dennis's Avatar
dennis
Originally Posted by phclub
This assy is triggered by the primary airvalve opening, is this correct. .
No. The unwinding of the choke coil as the engine heats ,pushes the choke rod up,(connects through the hole), opening the choke flap. At the same time the choke mechanism all rotates,(as my finger simulates in the video), pushing that lever to unlock the secondaries.
So, to answer your question, it's the setting of the choke that locks out the secondaries. Once the engine is warm and the choke is fully opened, the choke system has nothing to do with the secondaries
BTW a side note: when you push the gas pedal before cranking over the cold engine, everything closes in a sort of reverse order to opening. The only other thing to mention is, at this start up time, the fast idle cam rotates on the closing to set your fast idle. (adjusted with the screw seen in the video)
WHEW!! sounds like describing the mouse trap game.
Old Mar 26, 2007 | 10:37 PM
GD70's Avatar
GD70
Originally Posted by dennis
Old age. The memory is shot. Anyway, you can divide the operation,(or lack of), the secondaries into mechanical or vacuum. The vacuum side has been discussed. Engine vacuum corresponding to air valve opening. Also the choke operation locking out the secondary throttle plates.
One last thing, moving to the throttle side of the carb. What physically opened the secondary throttle plates is the rod linking the primary throttle lever to the secondary lever. It is possible there's an issue there but its easy enough to check. With the car not running, block the air valve open so you can see the throttle blades.Hold the vacuum lockout open. Then open the throttle linkage. At halfway or so the secondaries should begin to open. With the throttle opened fully the secondaries should be opened to a point just shy of vertical.
I just went out to see if this worked and the secondary plates did not open. So what do I adjust?
Glenn
Old Mar 27, 2007 | 05:56 AM
dennis's Avatar
dennis
Glenn
Could be a few things here. I'll try to get a pic or two posted of the linkage, but try this. First make sure there's a rod connecting the primary throttle to the secondary.(that's the easy one )
If it is, look where it connects to the secondary throttle linkage. There's a vertical sort of arm that gets pushed against by that rod to open the secondary's.
You can push rearward on that arm to directly open the secondary's.(you'll have to keep that vacuum lock out opened as before). If they open, you have an issue from the primary side to secondary adjustments.
You'll notice some resistance as you push on that arm to check. That is as it should be, since there are 2 springs to open and close the secondary. If ,after you have tried this arm pushing method and you don't feel resistance or the secondary's still don't open, you need to look at all the linkage associated there.
Old Mar 27, 2007 | 09:42 AM
GD70's Avatar
GD70
I did as you suggested and the linkage did just as you described, but the secondaries didn't open. I have to push the arm 1/4 turn more and then they open almost verticle. It's as though the rod is not long enough to push the secondary's open. Is the adjustment in the spring-arm relationship to engage it at an earlier point?
Old Mar 27, 2007 | 02:18 PM
dennis's Avatar
dennis
The roe q-jet book would be a great investment. It sounds like your adjustment is way off.
There are easy ways to fix this. First being to bend that rod to simply open the secondary's sooner and further. Not the right way. There are clearance issues you should take into account.
I'll try to get the photo and adjustment procedure later.
Old Mar 27, 2007 | 03:07 PM
GD70's Avatar
GD70
Ok Dennis, Thanks! I hope this isn't too much trouble. It's amazing how something that would seem so simple causes such frustration!
Old Mar 27, 2007 | 03:27 PM
dennis's Avatar
dennis
No problem .I actually enjoy this. Here's adjustments for opening and closing secondary's from the rebuild Q-jet sheets. Shows how to set everything. Have to figure out how to make it larger. Think you can go to my pics and see it larger
Pic of the secondary lever
Old Mar 27, 2007 | 04:03 PM
GD70's Avatar
GD70
This is awesome! I went to your pics but it wasen't there to view larger. Can you pm me the scan? I have photoshop on my machine and can blow it up larger to read the text.
Glenn
Old Mar 27, 2007 | 04:13 PM
dennis's Avatar
dennis
Glenn
PM me your email and I'll attach it.
Old Mar 27, 2007 | 04:18 PM
sly vette's Avatar
sly vette
I know this sounds awfully simple, but don't overlook it....REMOVE THE FLOOR MAT!!!
Old Mar 27, 2007 | 09:57 PM
GD70's Avatar
GD70
Thanks for the suggestion but I don't think it's the floor mat. I can open the primary fully to the end of the plastic sheathing on the throttle cable where it can't go any further. It's definately the rod not engaging the secondarys to open them. I'll need to play around with that adjustment.
Thanks, Glenn
