Car Cover Cleaning
Old Mar 24, 2007 | 11:24 AM
JustForFun's Avatar
JustForFun
Default Car Cover Cleaning
I splashed some tranny fluid on my car cover...Not sure of the brand of the cover, but its a higher end one. Couple spots it got it got it pretty good. Any ideas on cleaning it? Can it be dried cleaned, or can it just be run thru the washer?
Old Mar 24, 2007 | 12:18 PM
Durango_Boy's Avatar
Durango_Boy
Do you still have the packaging or at least know the manufacturer? I would suggest looking on their site or checking with them directly. They will have washing instructions available, as you are probably not the first person ever to need to wash their cover.
P.S. I usually run mine through the washing machine.
Old Mar 24, 2007 | 04:44 PM
Red 69's Avatar
Red 69
I have an old motor oil stain on my Mid America car cover. After spraying is well with fabric stain remover, I ran it through the washer using regular laundry detergent. It came out fine, but a faint motor oil stain remained. No matter, it is now clean. I don't see how running it through the washer can hurt, unless a tag on it says otherwise.
Old Mar 24, 2007 | 04:47 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i would only spot wash it....goop hand cleaner is a great degreaser
Old Mar 24, 2007 | 08:01 PM
mooneyd's Avatar
mooneyd
I have a Wolfe cover and they say you can machine wash it, but let it air dry. I did mine that way, came out fine.
Old Mar 24, 2007 | 11:14 PM
7T1vette's Avatar
7T1vette
I agree with D_boy. Check web site or call the manufacturer. Do the wrong thing and the stain is permanent...or worse! If you just don't know who made the cover, I think the hand cleaner idea is a good one (sugar beet stuff dissolves grease really well and is water soluble after you're done).
Old Mar 25, 2007 | 12:25 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I have washed mine once a few years ago. I am thinking of taking it down to the laundry mat and putting it in their machine that is setup for big loads. Wash it in cold water and dry it on the lowest setting in their dryer till it is slightly damp.
Old Mar 25, 2007 | 07:22 AM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
Default bad experience
i had trouble putting my wolf cover in my washer.... tore the cover by the windshield worse than it was already. also messed up my washing machine by being heavy on one side once wet. then when it spun out it chewed up the tub a bit on the edge. (pieces of fiberglass or plastic hanging off the edge) be smart and check things out first then if its ok. use a landry mat!!!
Old Mar 25, 2007 | 10:23 AM
Big2Bird's Avatar
Big2Bird
Machine wash gentle in large washer. Cold water, ivory snow detergent only, air dry only.
Old Mar 25, 2007 | 10:27 AM
Duke94's Avatar
Duke94
Yep, washing machine. Do it when the wifes not home.
Old Mar 25, 2007 | 11:36 AM
Big2Bird's Avatar
Big2Bird
Important detail I left out. Good call.
Old Mar 25, 2007 | 12:38 PM
rihwoods's Avatar
rihwoods
Take it to a laundry mat...some have big commercial washing machines...
Old Mar 25, 2007 | 12:52 PM
bobs77vet's Avatar
bobs77vet
did i ever tell you about the time i heat baked the headers inthe oven when she was sleeping......i made a "tent" around the stove and turned on the outside microwave vent
Old Mar 25, 2007 | 01:06 PM
rihwoods's Avatar
rihwoods
I got thrown out of a laundry mat once for trying to wash foam filters from a dieisel engine off a ship once...they were 4 Ft x 10 ft long...4 of them...
Owner: "You takey your foam and get out of my waundry"
Rich
Old Mar 25, 2007 | 01:08 PM
Big2Bird's Avatar
Big2Bird
How much to keep this a secret?
Old Mar 25, 2007 | 04:25 PM
79 vette head
St. Jude Donor '10
thats what i did and when she went to use it next she saw the marks in the washer and FLIPPED OUT
Old Mar 26, 2007 | 10:22 AM
427basketcase's Avatar
427basketcase
Go to the laundermat and use the 75 lb washer. DO NOT USE THE DRYER! I ruined a cover with the dryer on the lowest setting, the thing will stay in one spot and it will melt in that spot in the basket. (a nice little bumpy pattern that is hard and scratches the paint!) Now I use the 75 lb washer and bring it home damp and use 6 patio chairs to strech across and let it air dry.
To Car Cover Cleaning
Old Mar 26, 2007 | 11:15 AM
Wuttin's Avatar
Wuttin
Instructions with my Max Tech cover (similar to wolf/NOAH, generic from Corvette America) says to wash in a NON-AGITATING washer and to use liquid Fantastic, not regular laundry detergent. This also helps to resotre some of the water repelency. Haven't tried yet so can't comment.
Old Mar 26, 2007 | 12:25 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader vette
1Part Baking Soda 1 cup water mix soda on rag wipe till spot goes away
Old Mar 26, 2007 | 04:41 PM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
The directions for mine which is a 3 part cloth cover says that it can be washed, but you don't rinse it and it is to air dry. I did this and it came out like new again.
