Engine - some progress....
Old Mar 24, 2007 | 10:33 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Default Engine - some progress....
I had to modify the Summit engine cradle a little so that the engine and the trans fit....
Installed flywheel and clutch:
and the bellhousing:
oh yes, the old engine is out:
Old Mar 24, 2007 | 11:45 PM
Durango_Boy's Avatar
Durango_Boy
Good job.
I can't wait to see that beast in the car, rumbling.
Old Mar 25, 2007 | 09:58 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
For those who are interessted:
this is the cheap engine cradle from Summit. I cut the rear vertical section of square tubing off and re-welded it horizontally, extending the whole frame towards the tranny. I then added two pieces for stability and two additional castors.. I'm going to add a support for the trans once I've determined the correct location.
I'll have to add two engine supports that bolt to the side of the block, there's a 3/8" threaded hole on each side of the block. Right now I'm using a temporary support under the oil pan (from HomeDepot's
shelving dept.)
This thing is perfect to store an old engine and trans, cost less than $60
Old Mar 26, 2007 | 12:57 AM
sperkins's Avatar
sperkins
Originally Posted by MYBAD79
Poor thing looks like it's lying there dead.
Looking good man!
Old Mar 26, 2007 | 08:58 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Looking good man!
Thanks, it's not dead yet, it's in a deep coma... I'll wake it up once I'm done with the stroker.
Old Mar 26, 2007 | 10:24 AM
my2nd78's Avatar
my2nd78
Very, very nice.
To Engine - some progress....
