Is this numbers matching?
Old Mar 30, 2007 | 12:29 PM
Shark Mann's Avatar
Shark Mann
Default Is this numbers matching?
If a '69's engine was replaced under warranty with another CE block, is that still considered #'s matching?
-Shark Mann
Old Mar 30, 2007 | 12:33 PM
Tommy Samuels's Avatar
Tommy Samuels
uh, no
Old Mar 30, 2007 | 12:36 PM
Mike Ward's Avatar
Mike Ward
uh, maybe.
What's your definition of 'numbers matching'?
Good luck.
Old Mar 30, 2007 | 12:38 PM
moosie982's Avatar
moosie982
but with enough supporting documentation it would ease the sting some,,,wouldnt it,,,,,?
Peace,,,Moosie
Old Mar 30, 2007 | 12:41 PM
crazywelder's Avatar
crazywelder
If it was replaced under warranty and the owner has the original repair order with the correct VIN#, pink copy, not a zerox, I would say yes.
Old Mar 30, 2007 | 12:42 PM
Tommy Samuels
Peace,,,Moosie
I think it's hard to be sure Moosie. If you've got all the original documentation, work order for the dealer, r whatever, then maybe. I still think it would be looked at as a NOM though.
Old Mar 30, 2007 | 12:48 PM
moosie982's Avatar
moosie982
Yeah, if it was replaced under warranty , not as an upgrade, cause that was done also. So it could be #'s matching but NOM ? Providing there is proof of the "repair" ? Only questions,, no answers! Peace,,,Moosie
Shark Mann's Avatar
Shark Mann
I don't think any documentation is with the car. I kinda thought it wouldn't be, but seemed like I read something on here a while back that made me second guess. With that said, I was looking at buying this '69 http://cgi.ebay.com/ebaymotors/corve...94967929QQrdZ1. I know the frame is FULL of rust, but that can be replaced. The seller says the pillars are ok, but with that much rust on the frame, wouldn't the rest of that car be a rust bucket?
-Shark Man
Old Mar 30, 2007 | 12:53 PM
Tommy Samuels
I looked at that ad pretty closely when it popped up. It's possible the bird cage is still good, but I'd want to be up close and personal with that car before I dropped 5 grand.
Old Mar 30, 2007 | 02:31 PM
Shark Mann's Avatar
Shark Mann
I wish I were closer so I could go look at it
Old Mar 30, 2007 | 02:44 PM
Tommy Samuels
There are forum members in that area. Recruit some help and you'll probably get someone with reasonable C3 experience to be your long distance eyes and ears.
Old Mar 30, 2007 | 02:55 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I disagree. VIN or no VIN on the paperwork, warranty or no warranty, the original engine is gone and the CE block has replaced it. This car would not be matching numbers.
If the engine had been replaced in the heavy repair section at St. Louis before the car was shipped, the VIN derivative would have been stamped on the replacement engine by assembly plant personnel. That would meet the definition of "matching numbers" since the car left St. Louis with a block replaced at the factory and with the correct VIN.
Old Mar 30, 2007 | 03:05 PM
7T1vette's Avatar
7T1vette
By your definition, anything put on the car by the dealer would then be non-original. How about a luggage rack [only put on by the dealer]? How about a right side mirror? The point is, if the car was repaired for a defect MADE BY THE FACTORY, why is the replacement block not considered NOM if the owner has the paperwork to prove it?
Old Mar 30, 2007 | 03:16 PM
RagTop69's Avatar
RagTop69
I would think that a "numbers matching" car would be one where the numbers on the engine and the VIN matched. If the numbers don't match, then it's "non-numbers matching". Does it really matter whether the engine was replaced at the factory or at the dealer or at Joe's Machine Shop? The numbers still won't match.
Old Mar 30, 2007 | 03:21 PM
Mark_Milner's Avatar
Mark_Milner
-Shark Mann
Numbers matching means nothing. Period.
If the CE is installed in the first few months, it may have the same casting number for the block as the original and the date code may precede the build of the car. In which case, you could judge the car in NCRS and only have the hit for no VIN and no assembly code.
If the install was a year or two later, the CN may or may not be right and the date code is most likely AFTER the build of the car. In NCRS judging, you'd take the full hit on the engine.
With today's narrow-minded market, only ORIGINAL engine is worth any money and NUMBERS MATCHING is only worth money to those who have no idea what NM means.
The CE is no way original, so it is NOM. End of discussion on that point.
Now is the CE any good? I would buy one in a second, if the rest of the car was good, as a driver or a personal car. Search Yahoo for CE blocks. I agree with that web page that comes up that this is the only case where Chevy reenters the life of one of its cars after it has left the factory. I think it makes them special. However, no one pays for that specialness.
I would not buy one as an investment or for judging.
Old Mar 30, 2007 | 03:37 PM
rihwoods's Avatar
rihwoods
Replacement engine...not uncommon but not considered original "numbers matching"...correct engine for "period" if castings same year...
Old Mar 30, 2007 | 04:34 PM
PRNDL's Avatar
PRNDL
Thank you. If people insist on using this silly term, then use it and live with what you get. If I put a crate engine in my vette and stamp my vin on the crate engine, then as far as I am concerned it is a "numbers matching" engine. If the factory messed up and mixed up 2 engines on the assembly line, and my engine stamp differs from my vin by one number (This has happened), then I do not have a numbers matching car and in fact the factory produced a non-numbers matching car.
NOM stands for, Non, Original, Motor. A CE block is a non-original motor. You can't really call it an original engine, can you? Don't confuse the meangingless term "matching numbers" with "original." I know what original means, that's how the car left the factory. Dealer add-ons are not original. They might be cool, and they might be as old as the car, but they are not..., let's call it factory original.
If you are having a car judged by NCRS it can do very well with a CE block, even if it is NOM.
To Is this numbers matching?
Old Mar 30, 2007 | 04:41 PM
garage-ghost's Avatar
garage-ghost
-Shark Mann
Short answer...NO.
Old Mar 30, 2007 | 06:52 PM
Shark Mann's Avatar
Shark Mann
Cool. Thanks for clearing this issue up for me
-Shark Mann
Old Mar 30, 2007 | 07:16 PM
Ironcross's Avatar
Ironcross
Originally Posted by garage-ghost
Short answer...NO.
If you dont agree, try and sell it and see how quick your shot down. Personally I dont give a damn especially if it`s a UPGRADE engine. A 'Lotta HP'. Just dont try to pass it off as something it isn`t.
