Painted Chrome
Old Mar 31, 2007 | 03:44 PM
jwoodbury's Avatar
jwoodbury
3rd Gear
Default Painted Chrome
I have a 1978 Corvette. It has not been restored but runs great. There is a large piece of chrome around the rear window. The inside edge of it was painted black and is badly worn off.
Does anyone know how to restore the black to this Chrome edging.
Old Mar 31, 2007 | 03:52 PM
1982CorvetteDude's Avatar
1982CorvetteDude
Simple
Wet sand any and all the chips down with 220 or 320 grit depending on the severity, then go over it with some 400 grit.
Get a can of dupli-color trim black spray in the can from your favorite parts store and begin the re-spray
apply a light mist first and let it tack up, then apply a second coat to cover evenly, and it wouldn't hurt to do a third. Let it dry for a few hours before you handle it.
It helps to have the trim off the car and weather is at least 70 degrees
after that it'll look factory fresh
Old Mar 31, 2007 | 05:25 PM
onaqwst's Avatar
onaqwst
paint pens for edge work
Old Mar 31, 2007 | 05:39 PM
SmokinBBC's Avatar
SmokinBBC
Is it neccessary to prime chrome first?
Old Mar 31, 2007 | 07:00 PM
Jims79's Avatar
Jims79
It helps. they make a special chrome primer which eches the chrome to help the paint stick better. But it can be sprayed in a small area w/out.
the best way to fix this is to remove the trim & repaint the entire piece.
Old Mar 31, 2007 | 09:24 PM
1982CorvetteDude
The rear glass trim is stainless steel, not chrome
To Painted Chrome
