Removing ArmorAll from dash
Old Apr 1, 2007 | 02:08 AM
Sprzout's Avatar
Sprzout
Default Removing ArmorAll from dash
Ok...Most of us know that Armor All leaves a silicon residue which can be months, sometimes YEARS in getting off of a surface.
Well, I'm pretty sure there's some on the dash of my C3. And of course, I'm trying to clean it off, because it feels oily and REALLY slick & nasty...The previous owner probably used it thinking it was going to keep the dash shiny (In the 70's, Armor All probably was the popular thing to use).
Anyone know of any products I can use to get it cleaned off?
Old Apr 1, 2007 | 02:24 AM
mr nasty's Avatar
mr nasty
Rubbing alcohol will remove Armorall, but I am not sure if it will harm your dash.
Old Apr 1, 2007 | 02:30 AM
Sprzout's Avatar
Sprzout
Thanks...I'll just try it on an inconspicuous point first and see if it creates a blemish or something.
Old Apr 1, 2007 | 02:34 AM
SEVNT6's Avatar
SEVNT6
ArmorAll cleaning wipes work great.............
Old Apr 1, 2007 | 08:41 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
how about some mild soapy water
Old Apr 1, 2007 | 09:11 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Dawn?
Old Apr 1, 2007 | 09:34 AM
Roughrider's Avatar
Roughrider
The best care care products I've ever used are those from Griot's Garage. Check their website out and see what they have that will help you.
Old Apr 1, 2007 | 10:13 AM
sarchevyman's Avatar
sarchevyman
Wash it a couple times with Dawn Det and warm water. Then you can use some wax and grease remover, I used the same stuff I use when I paint a metal panel. Did all of this before I dyed a dash and had no issues.
Old Apr 1, 2007 | 10:14 AM
Dr.G's Avatar
Dr.G
I used to work in a prototype/fab shop, we would clean all dash areas with windex. It cleans and will not leave a shine.
Old Apr 1, 2007 | 10:17 AM
crazywelder's Avatar
crazywelder
Fantastik spray cleaner works well to remove Armorall without using damaging solvents. Use a soft bristle toothbrush to get into the grain and rinse with hot clear water and dry with a cloth. It might 2 or 3 applications to get all of the Armorall off. Then find a product that will soften the vinyl but won't leave a residue such as Murphy's Oil Soap.
Old Apr 1, 2007 | 10:29 AM
SEVNT6's Avatar
SEVNT6
Their stuff is the best......
Old Apr 1, 2007 | 10:43 AM
1mollyd's Avatar
1mollyd
When I was going to refinish the plastic interior components, I purchased a product made by Sherwin - Williams.
It is called "Aqua - Prep SC155". It is specifically for removing silicone residue.
Dave
To Removing ArmorAll from dash
