From: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
Trailering a C3
I did a search on trailering a C3 but did not find any good stuff on the subject. May of been there but if so I missed it. Any opinions on the best way to tie down a C3 in a enclosed trailer?
I haul both my '71 coupes in enclosed trailers all over the U.S. Some owners like to criss cross the straps, others strap them parallel. You can use the key hole slots in the side frames as the original transporter did. I just use one strap on front and one on back. The front strap goes around the lower control arm where it attaches to the center crossmember, the back strap is wrapped around the leaf spring near the center section.
Have hauled these cars more than 25,000 miles this way, no problems. I think the most important thing, is to use good nylon commercial straps with good racheting mechanisms with good hooks/clips on the ends.
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
I trailered mine in an open trailer, but I tied mine down using the large cross member under the engine in front and the batwing in the rear. I used a 10,000lb ratcheting strap for each one. Right or wrong, I had no problems.
didn't the factory put wooden blocks between the frame and suspension do the car wouldn't bounce an loosen the straps?
I thought it was in the AIM
I've always heard to tie down the suspension not the frame so the bouncing doesn't snap the straps...
This is an old racer trick. The idea is you tie the frame down to sit on blocks so it doesn't bounce up and down any. On a race car, that is using up your racing shocks, springs, and so on. Plus you don't have to pull a fragile frame (formula car) that hard to limit bounce. Slide a block under that clears by 1/4 inch, and you need very little pressure to hold it solid with the block, unlike compressing the suspension on a car until it doesn't bounce.
Originally Posted by LYLE
I like wheel bonnets on all four tires. You don,t need to get under the car and it is fast.
The problem with wheel bonnets is that the car body will bounce around a lot, depending on the spring stiffness of the trailer. This means it is getting the same wear and tear on suspension parts (almost) as driving it, so what is the advantage.
