coolant leak
Old Apr 3, 2007 | 10:58 AM
81cali's Avatar
81cali
Default coolant leak
Someone told me that coolant is corrosive, is this true? The heater core on my DD gave out w/o my knowledge and leaked coolant in the car soaking the front carpets. What should I do?
Old Apr 3, 2007 | 11:11 AM
rihwoods's Avatar
rihwoods
Just vacuum up coolant with a shop vac....then scrub carpets with soap/water...vacuum again...as a final clean,use Tuff out of a spray can...
Rich
Old Apr 3, 2007 | 12:04 PM
81cali's Avatar
81cali
I'm just worried that it might rust out the floor boards, no? Thanks for the advice Rich.
Old Apr 3, 2007 | 12:14 PM
TimAT's Avatar
TimAT
Rich
Pull the carpets up, clean them, dry the heck out of everything, and if you're still concerned about rust, maybe a little LPS 3 on the floor before the carpet goes back down.
Old Apr 3, 2007 | 12:47 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Your 81 ought to have factory undercoating/sound deadener on the floors beneath the carpet and pad.
Young69Owner's Avatar
Young69Owner
The floor boards are fiberglass. Clean it up and you'll be fine.
Old Apr 3, 2007 | 12:51 PM
81cali's Avatar
81cali
Thanks to all............
Old Apr 3, 2007 | 03:37 PM
Xakk's Avatar
Xakk
81 floor boards are steel.
To coolant leak
