headlight knob
Old Apr 3, 2007 | 03:31 PM
jnb5101's Avatar
jnb5101
Default headlight ****
ok, i give up-what's the trick to getting the **** and shaft out of the headlight switch on my 70? a bigger hammer?
Old Apr 3, 2007 | 04:59 PM
Durango_Boy's Avatar
Durango_Boy
There is a small spring loaded button on the body of the switch itself.
Pull the **** to it's out position, then press that button, and finish pulling the **** and shaft out of the switch.
It's so easy you'll kick yourself after you get it out. Just remember that you cannot push the button until the **** and shaft are in their out position.
Old Apr 3, 2007 | 06:19 PM
markdtn's Avatar
markdtn
what he said. You have to be a contortionist to get to the button to push it though.
Old Apr 3, 2007 | 06:31 PM
Kilroy1024's Avatar
Kilroy1024
This keeps coming up.
If you would refer to my stock photo.....
Push the button down and pull!
Old Apr 4, 2007 | 07:45 AM
jnb5101's Avatar
jnb5101
thanks for the help
jeff
Old Apr 4, 2007 | 12:34 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Standard GM **** release. No matter what the switch looks like, it's got one of those little beasties.
Old Apr 4, 2007 | 12:45 PM
Durango_Boy
Mopar did the same thing for a long time, and even my old Scout II had one like that.
Old Apr 20, 2007 | 11:42 PM
EyeLuvCorvettes's Avatar
EyeLuvCorvettes
I was just about to ask about this, I feel really stupid now lol. When trying to get the stock one out I couldn't figure it out and since I had to replace it anyways I just pulled and it broke.
Old Apr 20, 2007 | 11:58 PM
Durango_Boy
Did you stumble on this thread or search for it? Glad you have some insight for the next time.
Old Apr 21, 2007 | 12:10 AM
Big2Bird's Avatar
Big2Bird
Standard **** release. No matter what the switch looks like, it's got one of those little beasties.
Ford used this also. It's a generic design
Old Apr 21, 2007 | 12:48 AM
EyeLuvCorvettes
I searched for it, for as I read these things get asked alot. I actually already recieved my new switch and put the **** in to check the lights and then realized that I was an idiot for doing that without having put it through the dash pad. All is fine now, Thanks
Old Apr 21, 2007 | 01:13 AM
TimAT's Avatar
TimAT
That's the VERY FIRST TIME anyone has EVER done that!!!
j/k
Old Apr 21, 2007 | 08:26 AM
Durango_Boy
j/k
Hah hah, even with that sticky by Batman?
Old Apr 21, 2007 | 08:47 AM
TimAT's Avatar
TimAT
Yep.. It's kinda like flaring a tube and then finding the nut laying on the bench..
Old Apr 21, 2007 | 09:26 AM
SULLY_PA's Avatar
SULLY_PA
Been there just did that...now i have to get a new one..duh :o
Old Apr 21, 2007 | 09:29 AM
Big2Bird's Avatar
Big2Bird
Old May 24, 2007 | 05:25 PM
FKING1's Avatar
FKING1
I got the **** off my 70 switch, but, how does one get the switch body off the instrument panel?
To headlight knob
Old May 24, 2007 | 06:02 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
IIRC, the bezel on the outside screws onto the switch body. If it's tight, try rocking the switch back and forth a bit.
Old May 25, 2007 | 08:06 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Lock nut behind the ****. Do you have the AIM? Picture of it in the AIM.
Old May 25, 2007 | 08:51 PM
FKING1's Avatar
FKING1
Found it. There is a slotted threaded cylinder that screws in from the front bezel that is visible after removing the ****. Used a wide screw driver to take it off and install the new switch. Headlight problem solved too.
Thanks for the replies.
