1968 Steering column appearance?
Old Apr 5, 2007 | 10:10 PM
Vette Flashbacks's Avatar
Vette Flashbacks
Default 1968 Steering column appearance?
Here's what I do know. All 1968 Corvette steering columns were painted to match the interior color (at least the column section between the steering wheel and instrument panel). The paint should be semi-gloss.
Here is where I need your help. What is the correct (NCRS) finish of the column section between the steering wheel and the instrument panel?
Specifically, is that column section smooth? Or, textured?
Thanks for your help.
Larry
Old Apr 6, 2007 | 01:04 AM
7T1vette's Avatar
7T1vette
Smooth. At least, it was on my '68 when I had it (in 1975).
Old Apr 6, 2007 | 08:48 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 7T1vette
...Smooth...
Mine is smooth. April build date. Hub is metal and is smooth; upper trim is hard plastic and smooth; lower trim is fiberglass and shows only a hint of vinyl pattern; ditto for the dash piece -- only a hint of vinyl pattern. Horn button is grained.
Semi-gloss matching the trim color would be correct for the column.
Old Apr 6, 2007 | 09:41 AM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
try Krylon semi-flat. If your car has a black interior, it's #1613.........looks great and matches
Old Apr 6, 2007 | 10:31 AM
427-390's Avatar
427-390
I did the center console and the upper part of the console (above the radio) with Krylon 1613. The match between the old finish and new finish is really good.
I too also have a '68 with an April build date, and the description Easy Mike provided on the steering column is how my steering column appears.
Old Apr 6, 2007 | 10:33 AM
Ironcross's Avatar
Ironcross
Mine {column} is gloss not flat and is a unrestored one owner 68 Vette with 28086 fast miles.
For your information might I add that only the 'leading edge' of the center 4 bars in the grill are argent silver....
To 1968 Steering column appearance?
