Side pipes
Old Apr 9, 2007 | 04:23 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Originally Posted by NHRalph
I was thinking of getting the Patriot side pipes. They come in various sizes, what would be the correct size for a 77 Vette, 50 or 60"?
Tanks;
Ralph
If you are looking at the 4 inti 1 pipes ( as shown above) you will need the 63" pipes. If you are looking for the shielded single pipes then you will need the 60" I think. You will need to confirm where the measurements start and stop from the adds on the single style pipes.
Old Apr 9, 2007 | 04:24 PM
NHvette's Avatar
NHvette
63" rings a bell ... yup H1165 is the one.
where in NH, Ralph ?
-Dave (in Brookline [Nashua area])
Old Apr 9, 2007 | 04:46 PM
EyeLuvCorvettes's Avatar
EyeLuvCorvettes
I was also thinking about doing these, (sorry to partial thread jack but) how do you install them to the headers?
NHvette - I used to live in the nashua area, but I moved to mass. I used to live off exit 4.
Old Apr 9, 2007 | 05:11 PM
c69vete's Avatar
c69vete
St. Jude Donor '07
If you are going to use Patriots with headders then use shorty headders or I think Hedman makes a set that turn the pipes out to the fenders instead of going to the back. Otherwise you will have to make a 180 and a 90 degree bend to get the exhaust routed from the collector to the pipe inlet. Do a search for side pipes and there are some pictures posted of the last set-up.
Old Apr 9, 2007 | 05:39 PM
stingraymaniac's Avatar
stingraymaniac
here is how i did mine:
and yes they are 63" long 2" inlet and 3,5" out
Old Apr 10, 2007 | 10:14 AM
NHRalph's Avatar
NHRalph
NHVette, I am up her ein Ossipee. I have 2 Vettes, 77 and an 86. I wanted to put shielded Patriot pipes on the 77, look good and get rid of the cat.
Old Apr 10, 2007 | 10:18 AM
NHRalph's Avatar
NHRalph
I wanted to use Headman headers ( already have them) and when I measured from rear of front wheel well openint to rear of door, 60" seems long and 50" seems to short..
A question about the 4 in 1, don't they get very hot for getting in and out of the car?
Old Apr 10, 2007 | 05:18 PM
c69vete's Avatar
c69vete
St. Jude Donor '07
Can't answer about the shielded ones but YES the 4 into 1's get hot. You won't get burned but twice if you are a slow learner.
Old Apr 10, 2007 | 06:16 PM
vettecollector's Avatar
vettecollector
I put them on my 77. Don't listen to the people who say you will burn yourself..........you know that they are there, I haven't burnt myself in the 8 years since I put them on. I do recommened reminding your passengers if they have not been in your car. The exhaust DOES NOT go in the car when you are at a light either.
Good luck...........sounds good already!
Old Apr 19, 2007 | 09:20 PM
bobbywyant's Avatar
bobbywyant
Default side pipes
Well got the side pipes mounted,put the mounts on the side of the frame as suggested worked great. Have one side hooked up working on the other tommorow night . Thank you guys for all the info. Bob
