Tach not working
Old Apr 13, 2007 | 07:02 PM
bobbywyant's Avatar
bobbywyant
Default Tach not working
I purchased a new tach board form corvette america, and tach is only working up around 4000 to 5000 rpm , has anybody else had this problem. My Vette is a 76
Old Apr 13, 2007 | 09:53 PM
psw5940's Avatar
psw5940
I have a 75. I put in a new Tach board about a year ago. I't worked OK for a while, now its pretty eratic.
Had the car dynotuned about a month ago. The Mech. said my tach was off about 500-600 RPM.
I may have it rebulit or just replace it with an aftermarket one.
IMO these original tach's are pretty old technology and the replacement boards are cheaply made, so they don't do a very good job.
Old Apr 13, 2007 | 10:35 PM
7T1vette's Avatar
7T1vette
I don't have an electric tach, but I think there is a chinzy little electrical filter on the signal line to it. Sometimes that thing goes bad or doesn't work properly and the signals get jumbled. If I remember what I read about it, you can't buy them but you can get the parts from Radio Shack to replace them and get it working correctly. (Pretty simple fix, I think.) Chime in you "elec - techs."
Old Apr 13, 2007 | 10:38 PM
gldnkngt's Avatar
gldnkngt
sometimes the damping fluid in the meter head dries up. This makes the take needle erratic. If it's the tach board, the ones from corvette central and ecklers are pretty much junk. Call J.Gardeners electornic tach repair. He's out pf PA and makes the best quality tach board I've found. His is the only one I use.
Old Apr 13, 2007 | 11:13 PM
Tewski's Avatar
Tewski
Veteran: Marine Corps
St. Jude Donor '06 thru'17, '23-'26
I purchased a Gardener's board from Zip, it worked like a champ after a little calibration. This article on corvettefaq talks about re-zeroing the needle when installing a new tach board. I used this info when I replaced mine.
http://www.corvettefaq.com/c3/RebuildSpeedo.htm
Also, some good info in this post. I know forum member Mike Mercury used to rebuild tachs(he may still do it), you might want to contact him.
http://forums.corvetteforum.com/show...ch+calibration
Old Apr 14, 2007 | 08:27 AM
bobbywyant's Avatar
bobbywyant
Thanks guys that helped alot, know where i went wrong now,have to pull it back out.
Old Apr 14, 2007 | 09:28 AM
80_vette's Avatar
80_vette
Since you already replaced the board with a new one,I would replace the tach filter in the hood.They are proned to let go after awhile
Old Apr 14, 2007 | 09:54 AM
Big2Bird's Avatar
Big2Bird
http://www.ecklers.com/product.asp?p...7&dept_id=1135
Old Nov 18, 2007 | 06:19 PM
Mike Mercury's Avatar
Mike Mercury
Originally Posted by Tewski
... I know forum member Mike Mercury used to rebuild tachs(he may still do it), you might want to contact him.
still do. Mainly focusing on stealth conversions of 1968 through 1974 mechanical tachs to electronic.
tim-yvonne@juno.com
To Tach not working
