Air cleaner help
Old Apr 17, 2007 | 02:03 PM
soccer794's Avatar
soccer794
Default Air cleaner help
What air cleaner bottoms can I use with this?http://store.summitracing.com/partde...5&autoview=sku
I'd like as big of a drop base as I can get. Problem is current one pushes down on the primaries accelerator pump, reducing some of its efficiency. Not drastically killing the car, but a big pain none the less. So which drop base can I use that won't cause this same problem? It's on a 454 with an ls6 intake if it matters.
Old Apr 18, 2007 | 07:52 AM
soccer794's Avatar
soccer794
no ideas?
Old Apr 18, 2007 | 07:54 AM
82MDVette's Avatar
82MDVette
I ended up buying a complete 14 inch Edelbrock chrome drop base setup and am just using the bottom plate with a K&N Air Filter and XTreme top.
Old Apr 18, 2007 | 08:38 AM
soccer794's Avatar
soccer794
How much of a drop? 7/8 1 1-1/4?
Old Apr 18, 2007 | 08:43 AM
82MDVette's Avatar
82MDVette
Can't remember off hand, but I think it was a 1" drop.
Old Apr 18, 2007 | 09:22 AM
SteveG75's Avatar
SteveG75
Take a look at the stock LS-6 and L-88 bases. Lots of drop on those. Here is an L-88 base:
Old Apr 18, 2007 | 10:37 AM
soccer794's Avatar
soccer794
I'm pretty sure thats what I have. Like I said the front sits a little too low, and partially pushes down on the primary shooter. Any idea what the actualy drop is? If I know that I can step it back a little and should be ok.
To Air cleaner help
