Homemade gaskets?
Old Apr 19, 2007 | 03:37 PM
stinger12's Avatar
stinger12
Default Homemade gaskets?
Just an idea. I have some 1/8 " rubber sheets sitting outside in the garage. Was thinking of maybe making the outside door handle gaskets out of it...and if it worked I was going to use it to make other gaskets possibly. Just trying to save money anywhere I can...it all adds up! Has anybody here tried to do something like this? Post pics.
Old Apr 19, 2007 | 03:44 PM
SIXFOOTER's Avatar
SIXFOOTER
I have had to make gaskets many times useing everything from paper grocery sacks to copper sheet. SOmetimes it works better than others. The problem I always had with rubber (like an inner tube) is cutting it smoothly enough to make a pretty gasket. Most gaskets are Die cut, so its a rubber stamp operation.
Old Apr 19, 2007 | 03:52 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
One of the first things that I learned in high school auto shop was how too make a gasket from a sheet of material and a ball peen hammer.
As Six says, the challenge is getting clean edges. A usefull skill to have if you need a gasket right away or the one you want isn't made any more. Sheets of material aren't as commonly available as they were though.
Should work fine for a door seal, but you might want to use a sharp exacto blade rather than a hammer
Old Apr 19, 2007 | 04:01 PM
stinger12's Avatar
stinger12
bump
Old Apr 19, 2007 | 04:08 PM
NHvette's Avatar
NHvette
For these items, I would just buy the entire "seal kit" ... not too expensive.
I would be afraid that the thickness is not exact and comes out looking not-so-great.
For stuff you cannot see ... go for it.
Old Apr 19, 2007 | 04:28 PM
stinger12's Avatar
stinger12
bump
To Homemade gaskets?
