Hoses to carb
Old Apr 24, 2007 | 10:14 PM
CPatt's Avatar
CPatt
7th Gear
Default Hoses to carb
I have a 78 L82 corvette that does not have the original air cleaner or the evaporative canister hoses hooked up. I have started hooking new evaporative canister hoses up but am stuck on where the hoses connect to the carb. I have hooked a hose from the bottom center of the carb to a tee that goes to the PCV and then down to the evaporative canister to two inlets through a Y. I need to know where the other two inlets on the evaporative canister connect. Also do the other two connect directly to the carb or do they T out to anything else? Most of the inlets on the carb are currently plugged.
Old Apr 24, 2007 | 10:46 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
This help?
Air cleaner hose connects to the carb in the rear, kinda pass. side.
Old Apr 25, 2007 | 07:33 AM
CPatt's Avatar
CPatt
7th Gear
On the diagram one side of a T goes to the EGR valve, another to the canister, what is the device on the other side of the T?
Old Apr 25, 2007 | 08:47 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
CPatt Order the '78 assembly instruction manual. It'll help. Other side of the tee is (I think) TVS (thermal vacuum switch).
Old Apr 25, 2007 | 08:50 AM
Paul L's Avatar
Paul L
It's the thermal vacuum switch (TVS) that controls the EGR.
Old Apr 25, 2007 | 01:00 PM
CPatt's Avatar
CPatt
7th Gear
Thanks for the information. I just placed an order for the assembly instruction manual as recommended.
To Hoses to carb
