Vin and Engine matching # ?
Old Apr 29, 2007 | 07:50 PM
stingray76l82's Avatar
stingray76l82
Default Vin and Engine matching # ?
Hey fellas
New to the forum hope i get this right. Here I go.
I have a 1976 L82 4 spd. Engine # 16S417132 V1223CHC
Door post # 1Z37X65417132.
I was wondering does anybody know where I can get information on this motor and body. I am in the middle of a rebuild. I would like to find information on this car. Any help will be appreciated.
Old Apr 29, 2007 | 08:52 PM
694speed350's Avatar
694speed350
From you numbers you gave:off the engine v= flint engine 1223+engine build date,chc=l82 350/210 net hp engine with 4 speed transmission.as far as the vin # 1=chevrolet,z=?,37= body, x=l82,65=?,417132= serial #. which means the car was built sometime in january 76. Check on the car for the trim plate which is mounted onthe drivers doorhinge pillar which will give the codes for the exterior paint color and the interior codes and also the body build date. Hope this helps. as far as the # stamped on the engine they match the car.
Old Apr 29, 2007 | 10:40 PM
stingray76l82
Default Thanks
Hey thanks for the help 694speed350. Thats what I thought . i just need to know if I was right. Thanks for the help. I found the trim plate but my eyes are playing tricks on me the car is silver black int.
Thank You
Old Apr 30, 2007 | 09:15 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by stingray76l82
16S417132 V1223CHC
These match.
V Flint Michigan engine assembly plant
1223 Date engine was assembled at Flint (December 23)
CHC engine suffix for '76 L-82 with 4 speed
Congratulations
Old May 3, 2007 | 11:42 PM
crazy
Guest
Posts: n/a
Hi 694speed350, i saw your reply to the vin eng matching question and wonder if you could me, i also in the middle of a restoration and like to know more
Paint – F-F (where can i find this colour and what colour is it?)
Body – A-908
Trim – 414A
Style – 19437
12/64
Vin: 194375S105133 (i have determind this now but like to know if can match to eng, transmission etc?)
Eng: CEA127423 (front right corner stamp plate)
eng: 3959521 (LH rear corner near firewall)
eng: F30 *3* (rh rear corner near distributor)
regards crazy
Old May 4, 2007 | 09:10 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by crazy
...Paint – F-F (where can i find this colour and what colour is it?)
FF is Nassau Blue http://www.corvettepaintcodes.com/
Body – A-908...
Body #908 built by the A. O. Smith Company in Livonia, Michigan and shipped to St. Louis.
Trim – 414A...
blue vinyl
Style – 19437...
coupe
12/64
December, 1964
Vin: 194375S105133...
the 5133rd 1965 Corvette assembled.
CEA127423...
replacement engine. CE indicates a Chevrolet engine replaced under warranty. Sad to say, it is not the original engine for this '65.
Any reason why you've posted Sting Ray information on the C3 forum? If this '65 belongs to you, I highly recommend Noland Adams' book, The Corvette Restoration Guide, Volume II 1963-67 These are out of print but copies are still available. This is the bible for C2s.
Old May 4, 2007 | 07:12 PM
crazy
Guest
Posts: n/a
Default Thx
Hi and thx very much for the reply and information, as for the message well i am new to this site and was the only way i could get something posted??,
regards crazy
To Vin and Engine matching # ?
