Tire size vs. Spedo Error
I saw a thread a few weeks ago with a tire size conversion chart but couldn't find it when I did a search. Any idea as to what speedo gear I might need to recalibrate my spedo. It's a L-46 and I believe it has the standard 3:36 rear.
Thanks in advance.
Glenn
Put in the tire you have and the tire you plan to get and it tells you the speedo changes. You could have someone go in front of you at exactly 60mph and check your speedo. Or use a gps device in your car for exact measurement of speed. You can fix the speedo with new tires if not too far off.
http://chevelleengineer.home.comcast.net/speedo.htm
