Need STAT help with electric problem
Old May 5, 2007 | 11:38 AM
VetteSurgeon's Avatar
VetteSurgeon
8th Gear
Default Need STAT help with electric problem
Put in new battery in my 71 and immediately heard a "pop" and saw smoke from behind the dashboard. Now the radio and all the gagues are out. Checked the battery and cables were not reversed. Pulled the cluster out and no obvious meltdown. Fuses look ok. Car runs fine. Headlights and wipers working. Please help.
Old May 5, 2007 | 11:55 AM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
Did the car sit for the winter if so Maybe A small mouse or something chewed on A wire or so not much else can cause a problem in that area, JUST PUTTING IN A BATTERY.
Old May 5, 2007 | 12:28 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
You better bring it by my place so I can take a look.
I'm in Mesa probably not to far away.
I'll be home all day Sunday Monday Tuesday Wednesday
Old May 5, 2007 | 01:09 PM
AzMotorhead
Does your ammeter still work??
What battery did you install?
To Need STAT help with electric problem
