78 SA Wheel Polishing
Old May 9, 2007 | 01:00 PM
Rclarendon's Avatar
Rclarendon
Default 78 SA Wheel Polishing
Do I need to strip a clear coat off my original 78 SA rims before I polish them. What compound is best for these rims. Thanks
Old May 9, 2007 | 01:14 PM
Mikes*Corvettes's Avatar
Mikes*Corvettes
Used Autosol on mine and did them by hand.
Came up nice.
Old May 9, 2007 | 01:34 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader vette
Mine had the coating all over but not shinny so I used really old rubbing compound with spit and 2hrs per wheel ,they look new, I used mothers to finish shine .Not the power ball. Just alot off muscle took three nights cause our(Me and Girlfriend) hands were hamburger. but well worth it in the end.She also helped with the radiator and her help was Much needed.
Old May 9, 2007 | 02:38 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Yes. Otherwise you're polishing the clear coat.
Old May 10, 2007 | 05:22 AM
hunt4cleanair's Avatar
hunt4cleanair
That was a clear lacquer if original. I carefully used lacquer stripper, brushing it on and removing with rags. It took awhile but eventually got it all. than do your polish as suggested by others. Oh, take the wheels off and do your work well removed from the vehicle.
Old May 10, 2007 | 09:36 AM
cs_sas's Avatar
cs_sas
I would like to do mine also. Where do you buy that Autosol? and how is it applied. I tried the other methods on one of the wheels and its a lot of work to get that laquer coating off.
Claude
Old May 10, 2007 | 10:58 AM
mvftw's Avatar
mvftw
I believe '78's didn't come with C/C. I think that started with the 80's... I used Mothers & the Mothers Ball to clean mine...
Old May 10, 2007 | 12:00 PM
rihwoods's Avatar
rihwoods
Mine did..bought it 28 years ago...removed clear coat using 400 grit wet/dry...then polished....turned out great...some follow up with 1000 grit before polishing...
Rich
To 78 SA Wheel Polishing
