Pulling out with a BB
Old May 13, 2007 | 09:12 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Default Pulling out with a BB
How the #^%& do you get these things going on street tires without just roasting the heck out of it?? I have a 73 with a "built" 454 and a Tremec TKO 500.
It will spin all the way through 1st unless you ease the throttle or slip the clutch a great deal. (which I ain't gonna do much) Then if you try to get back in it, it starts breaking loose again. After the first 30-40 feet of second you can actually open up the throttle 2/3 to WOT.
My first trip to the track resulted in 60' times all over 2.5 seconds.
My opinion right now is to just drive it and enjoy the "extra" torque. I didn't build it to race, I built it to cruise. (and pizz of Rustangs of course )
Any of you experienced drivers got an answer?
Old May 13, 2007 | 09:18 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Get an M-22 with 3.36 rear. gotta punch her 4,000 before the tires break loose even a little.
Old May 13, 2007 | 09:38 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
I sure do like cruising at 1700 RPM with the TKO and my 3.08. Wouldn't trade that for a hole shot.
Old May 13, 2007 | 10:50 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Drag slicks aside, precision throttle modulation becomes a required skill with healthy power to weight ratio's, street or track. Bigger/stickier tires will help to a point, but you'll just have to accept that the gas pedal isn't always an on/off switch. Look at it as an opportunity to become a more talented driver. Best of luck!
Old May 13, 2007 | 11:03 PM
shafrs3's Avatar
shafrs3
Get some stickier tires.
Old May 13, 2007 | 11:28 PM
68RATVT's Avatar
68RATVT
What are you running now for tires/rim size?
Old May 13, 2007 | 11:34 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Now you know why I re-configured my 540 to move powerband much higher. I intentionally killed low end TQ to make it more driveable under power. The first version was like a switch...on or off......
JIM
Old May 13, 2007 | 11:44 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I love that too, I wouldn't trade my 3.08's either. Get some stickier tires, I am getting 285/40/18 Toyo T1R's for the back of mine.
Will still easily break them loose but they should be much better that the TA's on there right now
Old May 13, 2007 | 11:54 PM
big_G's Avatar
big_G
A bigger cam will kill a little bottom end torque, making it more docile. I have Dunlop Qualifiers, 295's and they are useless above 3,500.
Old May 14, 2007 | 01:55 AM
7T1vette's Avatar
7T1vette
Start in second gear.
Old May 14, 2007 | 11:31 AM
bashcraft's Avatar
bashcraft
Pull a couple plug wires off.
Old May 14, 2007 | 06:20 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Now there's an ................uh idea.
Old May 14, 2007 | 07:30 PM
Restorod '79's Avatar
Restorod '79
You're gonna have to brace your foot on the tranny tunnel and develop a light touch. After a while you should be able to stay on the edge of traction.
OR are you just braggin'?
Old May 14, 2007 | 09:26 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
No, I swear I ain't braggin. I would love to get this thing to launch like my Z06 used to. (dreaming I know)
I really think you are right, it is going to take a lot of doing to make it go.
Old May 15, 2007 | 12:41 AM
corvette502's Avatar
corvette502
drag racers know that the C-3's rear wheels need to be further back from the **** pit to apply serious hp to the ground.
However, stickier tires uhh, like ET streets or better, and change the spring to transfer the weight. Been there done that on several cars, simple changes will plant 700+ hp on the street and low 10's in the 1/4
chris
Old May 15, 2007 | 09:53 AM
TimAT's Avatar
TimAT
I'm running a 12 pound flywheel and it's still easy to break the tires loose- anytime. Get it rolling and jump on it, tires come loose. Jump on it at 40, same result. I suppose it may be the 4:11's. Either way it;s still a blast to drive.
Old May 15, 2007 | 10:13 AM
Augustus's Avatar
Augustus
2th farmer You must have one wicked ride!!! LOL
I have a 388 stroker in my 73 and just had headman headers #38830 2.5 inch exahust with Magnaflow mufflers just installed. The carb re-adjusted and now under full throttle from a standstill it rips the tires right off. No stall converter. (Stock stall) and I beleive 3.08 gears. On the Highway it's a missle. Way too much..
It won't break the tires at half throttle though. I need to hammer down as I have the Old. 780/800 Holley vacum secondary carb on it.
But with a 454 BB and a Tremec TKO OMG!!!
I would like to go with a M22 and 2.52 first gear. I believe Autogear has one that will work well with 3.08 gears.
I have Goodyear 255 Tires out back and 245's in front.
How about those semi/slick tires from Hoosier?
To Pulling out with a BB
Old May 15, 2007 | 06:42 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
I think tires will be the first place to start
Old May 16, 2007 | 11:48 AM
eastltd's Avatar
eastltd
Sticky tires break parts! Choose carfully, those half shafts are small.
Old May 16, 2007 | 04:33 PM
tshort's Avatar
tshort
CI 7-8 Veteran
If you plan on beefing up some of the rear end then go with some drag radials. I've been running 275/60/15 Nitto 555R's for almost 2 years now on the street and like them. They won't last anywhere near as long as regular street radials and they are slippery in rain but are much stickier on the street and strip than radials. I just finished putting in a 600+hp BB and although I've only driven it around the block a few times so far the tires hold it down really well. Other option is a bigger cam to kill a little bottom end.
