Thermometer reading 210
Old May 17, 2007 | 08:18 AM
Young69Owner's Avatar
Young69Owner
Default Thermometer reading 210
I replaced my tach cable, and now it always says 210. Could a wire have fallen out the back? Where does it go into the block?
Thanks, Adam
Old May 17, 2007 | 08:24 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I'm missing something. Tach doesn't have anything to do with the temp guage. Are you saying normal operating temperature now shows 210?
Old May 17, 2007 | 09:53 AM
SIXFOOTER's Avatar
SIXFOOTER
you may have pulled someting loose behind the dash. Put a ground on the temp sensor and see if the gauge moves, if not you got to pull the center dash and see whats what
Old May 17, 2007 | 12:10 PM
Young69Owner
Where is the temp sender? All I did was fix the tach, but I suspect something moved somewhere.
Old May 17, 2007 | 12:54 PM
7T1vette's Avatar
7T1vette
If your temp sensor is like mine ('71 sb), it is on the right side of the engine block. It has a black wire running from it. As mentioned above, the work you did either damaged that wire (in the engine bay area) or you broke/dislodged wiring when you were under the dash installing the tach cable. There is no relationship between the tach and the temp sensor...only that you were working in the same general area where they are routed.
Old May 17, 2007 | 01:04 PM
Dalannex's Avatar
Dalannex
The temp sensor is in the head on the side, kind of between the exhaust ports. It could be in either head, depending on what work has been done in the past. It has one wire on it. Take that wire off and run a jumper to ground there to see if your gauge works. You probably just pulled that wire off of the sensor. After a number of years the plug that goes on the sensor gets kind of loose.
-Justin
Old May 17, 2007 | 01:33 PM
Young69Owner
Thanks a lot guys. I remember there being a green wire on the driver's side. I'll take a look at it right after work. Thanks again!
To Thermometer reading 210
