2 Questions
Old May 19, 2007 | 03:18 PM
Richard Cooper's Avatar
Richard Cooper
Default 2 Questions
First, does anyone know where I can get a front seal for my Th350 tranny? I have the motor out and would like to replace the front tranny seal, it has a little drip.
Second, I think I already know the answere to this, but what the heck. I have a 1981 and have the motor out I am replacing it with a new crate motor and am NOT putting the computer back in the car. My old exhaust manifolds are totally cracked and cannot be welded. Plus, I don't want the pipes from the old air system on the manifolds. The rest of my pipes are like new. Is there a set of exhaust manifolds that bolt right on and align with the existing pipes? Thanks for any help.
Old May 19, 2007 | 03:24 PM
sperkins's Avatar
sperkins
I'm pretty sure I have a new front pump seal somewhere here in the shop from a rebuild kit I never used. I'll look for it and if I find it I'll send it to you.
Old May 19, 2007 | 03:25 PM
sperkins's Avatar
sperkins
Ok - I found it. Which front seal do you need?
Old May 19, 2007 | 05:38 PM
Richard Cooper
I did not know there were more than one front seal, I have my torque converter out and I see fluid dripping from the seal there.
Old May 20, 2007 | 01:24 AM
sperkins's Avatar
sperkins
Ok. I'll dig through the kit to see if I have what you need tomorrow.
Old May 20, 2007 | 06:55 PM
Richard Cooper
sperkins,
Thanks for your trouble, but I found the seals at NAPA for $4.00.
Old May 20, 2007 | 07:54 PM
sperkins's Avatar
sperkins
No problem. Glad you got it.
Old May 20, 2007 | 08:40 PM
ghoastrider1's Avatar
ghoastrider1
seems any exhaust maifold from a junk yard will fit..just make sure they look the same lenght and have the turn down in the same place.
To 2 Questions
